    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 100.6k Views 15 Watching
    • W Offline
      Woody
      @cato
      made a new installation as describek by @KirAsh4 with the same result as already mentioned but found some maybe related entries in the pm2 mm-out-0.log.
      > magicmirror@2.1.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.1.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-MotionEye
      All module helpers loaded.
      Starting server op port 8080 ...
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-MotionEye
      Starting module: MMM-MotionEye
      Launching application.
      Create new calendar fetcher for url: http://xxx
      Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
      Hiding camera: undefined
      Motion registered: undefined
      maybe a helpful hint ???
        Cato Module Developer
        I’m on vaccation until next week (back 8th of May) and don’t have any chance of doing any testing.
        Just wondering about your configuration. The values for width, autoHide, autoHideDelay and debug is not a string and you should not have the hyphen ( ’ ) around them. Not shure if it matters, but could you try to remove them?
        • W Offline
          Woody
          @Cato
          Hi, I had a bit more time over the weekend. By trial an error I found out that the problem is related to my motioneye URL string providing userid and password. Apparently the Electron browser can’t handle this. After disabling authorization in Motioneye the problem was solved. In another MM installation on a Pi Zero I use Midori as browser and this works since month without problems. Thanks for MMM-Motioneye and your help in this case.
            AWall
            • F Offline
              fox
              which camera du you suggest? I never had one. Should work for and in my garden (to observe the kids)
              Issues With MMM-WatchDog known?
              https://forum.magicmirror.builders/post/29827
              Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                Binog
                Just have a look for the noir camera. Have a look for amazon.com. There is an official cam - I think - by the raspberry company. But any other that support the onboard psi cam plug is imho better than usb cam. But that is your decision.
                  darbos @emos
                  @emos
                  I had that same issue. I ended up just creating a few mmm-mogioneye module entries in the config file
                    SdeGeata @Binog
                    @Binog
                    Did you ever get an answer back on this one? I am having the same problem. I see everything fine without autohide active, but if I activate autohide, I see it for a bit during page load and never again after. I get detected motion emails and photo uploads so the detection isn’t the problem. It just doesn’t get fed to the mirror module somehow. Maybe my Web-hook config is off?
                    It would be helpful to know if you fixed your issue and how you did it.
                      Binog
                      Hey, SdeGeata
                      No, actually I didn’t
                      I circumvented it by setting up a motioneyeos raspberry pi zero. As I needed the larger image on my Magicmirror I used “fast…?” option, which does not provide any of the motion activities,. what was fine to me.
                      I do think, this is not merely a problem of motioneye, but of the MM its self.
                      With every update of MM the Gap went bigger, I got more problems.
                      Now, streaming the motioneyeos to two MMs it is more steady, nonetheless I do habe outages. I don’t see a picture,. although my browser directed to motioneyeos shows an actual one. Restarting MM solves that issue- normally,…
                      Good look to You !
                        SdeGeata @Binog
                        @Binog
                        Thanks for the info. I’ll keep trying stuff out and see what happens.
                          SdeGeata @Cato
                          @Cato
                          So how do we use that Webhook URL to trigger the hidden module. I have been screwing with it for days trying to get it to work. Can you clarify the config for that?
                          • O Offline
                            OberfragGER @SdeGeata
                            @Cato
                            I really want to use the AutoHide feature. But the stream is fixed and always displayed. Is there any possibility…?
                            		module: "MMM-MotionEye",
                            		position: "bottom_left",
                            			url: "http://pihole:8081",
                            			autoHide: true,
                            			autoHideDelay: "10000",
                            			forcedRefreshInterval: 60000,
                            			width: "400px",
                            			debug: false
                            • O Offline
                              OberfragGER @OberfragGER
                              @oberfragger
                              ok. solved.
                              Somehow it was working after an hour or so.
                              Also- you have to enable access to the mirror via
                              address: “0.0.0.0” and whitelist
                              The the commands http://mirror:8080/motioneye and http://mirror:8080/motioneye/hide are working.
                                piwy
                                Bonjour à tous, comme beaucoup apparement, j’ai installé le module motioneye sur mon MM avec ces lignes dans mon fichier “config”:
                                	module: 'MMM-MotionEye',
                                		position: 'bottom_left',
                                		url: "http://monip:8081",
                                		width: 400,
                                		debug: true
                                Mais quand je lance Magic Mirror , j’ai une petite icone avec une image cassée.
                                Lorsque je rentre cette adresse ip :“http://monip:8081”, dans mon navigateur sur mon pc , je tombe sur une page qui me dit : “ce site n’autorise pas la connexion”
                                J’ai essayé de voir si sur motioneye il n’y avait pas des autorisations de connexions a mettre mais je ne vois rien .
                                Infos peut etre importante, motioneye est installer sur docker à travers portainer sur une VM!
                                Merci pour votre aide
                                  SdeGeata @piwy
                                  @piwy Salut Piwy;
                                  Essaye de changer des paramètres dans motion.conf & motioneye.conf. Il ne sont pas accessible de la GUI. Voir avec Terminal; /etc/motioneye/motion.conf et trouve webcontrol_localhost, si c’est “on” change ça pour “off”.
                                  En /etc/motioneye/motioneye.conf Change motion_control_localhost true pour motion_control_localhost false .
                                  Essaye ça.
                                  • 4 / 4
