MMM-ModuleScheduler - Module Schedules and Notifications
@strawberry-3.141 I didnt notice this - thanks for pointing it out. Thats exactly what i need!
Great idea, i’ve tried your module but i does not work for me. I might have missed a step or something.
I did put in the config file your module (after download and setup with
npm install
))) :{ module: 'MMM-ModuleScheduler' },
And then :
{ module: 'MMM-WunderGround', position: 'top_right', config: { module_schedule: {from: '0 14 * * *', to: '0 18 * * *' }, apikey: 'xxxxxxxxx', // private; don't share! pws: 'pws:IBOULOGN39', //culemborg hourly: '1', fctext: '1', fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "french:" }, classes: 'for_all default' },
It’s 13:30 and the weather is still showing on the mirror.
Thanks for your help
You’re missing the trigger ;)
Here do this:
{ module: ‘MMM-WunderGround’, position: ‘top_right’, classes: 'scheduler', config: { module_schedule: {from: ‘0 14 * * *’, to: ‘0 18 * * *’ }, apikey: ‘ad100f1e35ae51d2’, // **private; don’t share!** pws: ‘pws:IBOULOGN39’, //culemborg hourly: ‘1’, fctext: ‘1’, fcdaycount: “5”, fcdaystart: “0”, hourlyinterval: “3”, hourlycount: “2”, alerttime: 10000, alerttruncatestring: “french:”' } },
As @cowboysdude said, you need to configure the
classes
option to trigger the scheduler.As you already have the
classes
option set up for what looks like @paviro 's MMM-FacialRecognition module I would suggest trying the following config.{ module: 'MMM-WunderGround', position: 'top_right', config: { module_schedule: {from: '0 14 * * *', to: '0 18 * * *' }, apikey: 'ad100f1e35ae51d2', // private; don’t share! pws: 'pas:IBOULOGN39', //culemborg hourly: '1', fctext: '1', fcdaycount: '5', fcdaystart: '0', hourlyinterval: '3', hourlycount: '2', alerttime: 10000, alerttruncatestring: 'french:' }, classes: 'for_all default scheduler' },
Please do report back if you are successful because I haven’t tested the compatibility of the two modules :)
Opps didn’t realize you were using Facial Recognition… LOL
Thanks @ianperrin !!
Thank you both, it works with paviro’s MMM-FacialRecognition module.
Okay I have another curve ball for you… how about … the ability to turn the mirror off and back on with this? :)
+1, would be great to add this feature :)
+1, be really nice if it not only just dimmed the running modules, but actually shut off the monitor.
@dr4ke616 Well you could actually do it with a straight cronjob … something like this…
55 6 * * * /home/pi/monitor_on.sh
And off the same way :) It’s like making your own schedule…
