    [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io)
    81 Posts 13 Posters 79.8k Views 16 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor
      for me the test device is working (Office lamp or fan) but can’t find my modules
      SubLim3S 1 Reply Last reply Reply Quote 0
      • SubLim3S
        SubLim3 @Stoffbeuteluwe
        @Stoffbeuteluwe Yeah, I have been reading that the 3rd Gen Alexa devices are not locating the modules. You might try discovery through the app or web browser http://alexa.amazon.com.
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @SubLim3
          @SubLim3 i tried the app but doesn’t work…no device found
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor @MoreLinux
            @MoreLinux I have MM running on Mac I think you have a RPI …maybe this can be my problem
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
              @Stoffbeuteluwe is there anybody with a working module MMM-AlexaOnOff on Mac?
              test device is working …but no other device
              • StoffbeuteluweS
                @Stoffbeuteluwe anybody an idea?
                • SubLim3S
                  SubLim3
                  So IF I understand this log correctly, my mirror is receiving the Notification from my Alexa Device but the AlexaOnOff module is not operating correctly. Any suggestions?
                  module.js:154 MMM-WatchDog received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
                  module.js:154 MMM-Screencast received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
                  module.js:154 MMM-GoogleMapsTraffic received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
                  MMM-Remote-Control.js:43 Uncaught TypeError: console.log is not a function
                      at Class.notificationReceived (MMM-Remote-Control.js:43)
                      at sendNotification (main.js:95)
                      at Object.sendNotification (main.js:502)
                      at Class.sendNotification (module.js:368)
                      at config.devices.forEach.d (MMM-AlexaOnOff.js:47)
                      at Array.forEach (<anonymous>)
                      at Class.socketNotificationReceived (MMM-AlexaOnOff.js:37)
                      at module.js:246
                      at r.<anonymous> (socketclient.js:25)
                      at r.emit (index.js:83)
                    sdetweil @SubLim3
                    @SubLim3 edit the MMM-Remote-Control.js, and change all
                    console.log
                    To
                    Log.log
                    • SubLim3S
                      SubLim3 @sdetweil
                      @sdetweil Is this something that happened because I updated MMM-Remote-Control and MMM-AlexaOnOff does not have an update? If so, would it be better to update AlexaOnOff to have console.log instead of log.log? That being said, I could not find Log.log in AlexaOnOff.js anyways.
                      Are there other modules that will stop working if I change MMM_Remote_Control to Log.log? I saw it in there a couple of times and changed it. This did resolve the issue but I need to see if there are other Modules throwing red flags now.
                      Thank you for the Help! Hopefully MMM-AlexaOnOff gets an update to help everyone else with 3rd Gen Alexa devices get discovered.
                        sdetweil @SubLim3
                        @SubLim3 you are supposed to change console.log TO Log.log
                        So currently u will not find it.
                        Log.log is supposed to be used in the module.js file
                        • SubLim3S
                          SubLim3 @sdetweil
                          @sdetweil Correct. There were 2 instances in the MMM-Remote-Control.js where I changed console.log to Log.log and this did resolve my issue. I was more curious to know if this was an issue with AlexaOnOff not having an update or if it was due to Remote-Control updating to a newer build.
                            sdetweil @SubLim3
                            @SubLim3 that is a bug in remote control.
                            Don’t know how/when it might have got there
                            • SubLim3S
                              SubLim3 @sdetweil
                              @sdetweil I did find this line commented out near the top of the MMM-Remote-Control.js which may be where they are working to resolve this.
                              // Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                js989
                                Hi - I’m struggling with this module too. I have it installed with the dependencies. I can see that the ports are opened and listening. Alexa cannot find the devices. I’ve tried the examples too which have not been discovered yet either.
                                I have an Echo dot gen 3 in the house, on the same network as the mirror. I’ve tried searching for the device from the echo and the web portal - neither has worked. Any tips?
                                  sbrundage85 @js989
                                  @js989 Same situation here. Have not been able to figure it out. I found this resource which I believe may be a possible problem but have not been able to work through it. https://github.com/n8henrie/fauxmo/issues/38
                                    looking at this app, I think alexa v2+ devices have removed the builtin support for wemo devices which this depends on.
                                    so, you would have to install the belkin wemo skill… which requires actual devices
                                      but MMM_AlexaControl works, same concept… I use it for 4 Mirror devices (with alexa devices, not goggle home or GA)
                                      • 4 / 5
