    Mirror with no frame????
    6 Posts 5 Posters 3.0k Views 3 Watching
      mishkalidas Banned
      Hi everyone, I’m wondering if it would be possible to make a mirror without a frame. I have no experience at all so I was wondering if anyone who has built a smart mirror before could identify any potential problems with having a frameless mirror
      https://sarkariresult.onl/
      thedoorsfanaticT 2 Replies Last reply Reply Quote 0
        bhepler Module Developer
        There are a few mirrors here that are frameless. A quick browse through the Show Your Mirror section of the forum should turn them up.
        The most common approach seems to be using a super strong glue on the edge of the monitor to stick it to the mirror glass. At that point, you can use whatever technique you like to mount the monitor to a wall, even a VESA mount. The Raspi can be stuck to the back with velcro strips.
        One person (I forget who) had the glazier drill holes in the corners to allow mounting hardware to go through. He capped them with chrome caps after running bolts through the holes and into the walls. There are options.
        • T Offline
          truemark @bhepler
          @bhepler You can also use this: https://www.glasstekinc.com/product/2k-touch-foil/ on the back of the mirror over the tv to make it interactive.
            broberg Project Sponsor @truemark
            @truemark said in Mirror with no frame???:
            Probably not, but you are very welcome to make it work!
            • thedoorsfanaticT Offline
              thedoorsfanatic @mishkalidas
              @mishkalidas
              My mirror is still a work in progress but so far it is frameless. Check out my YouTube playlist
