    Won't restart/stuck at prompt
    16 Posts 5 Posters 7.4k Views 5 Watching
      sdetweil @motdog
      @motdog do
      pm2 logs
      M 1 Reply Last reply
        motdog @sdetweil
        @sdetweil OK. I’ll have to remove the pi from my mirror & hook up to a tv so I can try to get the info. Ive got screen rotated and its hard to read through the mirror.
          sdetweil @motdog
          @motdog ssh into mirror
            motdog @sdetweil
            @sdetweil when I connect via VNC I see something that says can’t currently display desktop
              sdetweil @motdog
              @motdog one of the reasons I don’t use vnc
                motdog @sdetweil
                  motdog
                  @sdetweil said in Won't restart/stuck at prompt:
                  pm2 logs
                  Is this what you were looking for?
                    sdetweil @motdog
                    @motdog sadly this looks like an SD card corruption. Bad file header loading library
                      motdog @sdetweil
                      @sdetweil well that gives me a weekend project then. Is the card reusable with a wipe or do I need to buy a new one?
                      mumblebajM 1 Reply Last reply
                      • mumblebajM
                        mumblebaj Module Developer @motdog
                        @motdog Probably easier and cheaper to buy a new card. There are some tools out there that you can use to check for bad sectors. But again it is probably cheaper and easier to buy a new one.
                          motdog @mumblebaj
                          @mumblebaj Thanks, thats what I figured
                          L 1 Reply Last reply
                          • L
                            lxne Project Sponsor @motdog
                            @motdog It is always a good idea to make a backup of a running system so you can clone it onto a new sd in case.
                            https://beebom.com/how-clone-raspberry-pi-sd-card-windows-linux-macos/
                              retroflex Project Sponsor Module Developer
                              In addition to having a img backup, it’s always a good idea to backup the config file and custom css file.
                              To avoid card corruptions, always SSH into the RPi and perform a sudo shutdown instead of just pulling the plug.
                              S M 2 Replies Last reply
                                sdetweil @retroflex
                                @retroflex i had one card suddenly go read-only…
                                  motdog @retroflex
                                  @retroflex I used the shutdown from MMM-remotecontrol to shut it down. 8 did have a backup of config & css on laptop so it was just reinstalling modules for the most part
