    Won't restart/stuck at prompt
    16 Posts 5 Posters 7.4k Views 5 Watching
      motdog @sdetweil
      @sdetweil OK. I’ll have to remove the pi from my mirror & hook up to a tv so I can try to get the info. Ive got screen rotated and its hard to read through the mirror.
        sdetweil @motdog
        @motdog ssh into mirror
        M 1 Reply Last reply
          motdog @sdetweil
          @sdetweil when I connect via VNC I see something that says can’t currently display desktop
            sdetweil @motdog
            @motdog one of the reasons I don’t use vnc
              motdog @sdetweil
                motdog
                @sdetweil said in Won't restart/stuck at prompt:
                pm2 logs
                Is this what you were looking for?
                  sdetweil @motdog
                  @motdog sadly this looks like an SD card corruption. Bad file header loading library
                    motdog @sdetweil
                    @sdetweil well that gives me a weekend project then. Is the card reusable with a wipe or do I need to buy a new one?
                    mumblebajM 1 Reply Last reply
                    • mumblebajM
                      mumblebaj Module Developer @motdog
                      @motdog Probably easier and cheaper to buy a new card. There are some tools out there that you can use to check for bad sectors. But again it is probably cheaper and easier to buy a new one.
                        motdog @mumblebaj
                        @mumblebaj Thanks, thats what I figured
                        L 1 Reply Last reply
                        • L
                          lxne Project Sponsor @motdog
                          @motdog It is always a good idea to make a backup of a running system so you can clone it onto a new sd in case.
                          https://beebom.com/how-clone-raspberry-pi-sd-card-windows-linux-macos/
                            retroflex Project Sponsor Module Developer
                            In addition to having a img backup, it’s always a good idea to backup the config file and custom css file.
                            To avoid card corruptions, always SSH into the RPi and perform a sudo shutdown instead of just pulling the plug.
                            S M 2 Replies Last reply
                              sdetweil @retroflex
                              @retroflex i had one card suddenly go read-only…
                                motdog @retroflex
                                @retroflex I used the shutdown from MMM-remotecontrol to shut it down. 8 did have a backup of config & css on laptop so it was just reinstalling modules for the most part
