    Won't restart/stuck at prompt
    16 Posts 5 Posters 7.4k Views 5 Watching
      sdetweil @motdog
      @motdog one of the reasons I don’t use vnc
      M 1 Reply Last reply
        motdog @sdetweil
          motdog
          @sdetweil said in Won't restart/stuck at prompt:
          pm2 logs
          Is this what you were looking for?
            sdetweil @motdog
            @motdog sadly this looks like an SD card corruption. Bad file header loading library
              motdog @sdetweil
              @sdetweil well that gives me a weekend project then. Is the card reusable with a wipe or do I need to buy a new one?
              mumblebajM 1 Reply Last reply
              • mumblebajM
                mumblebaj Module Developer @motdog
                @motdog Probably easier and cheaper to buy a new card. There are some tools out there that you can use to check for bad sectors. But again it is probably cheaper and easier to buy a new one.
                  motdog @mumblebaj
                  @mumblebaj Thanks, thats what I figured
                  L 1 Reply Last reply
                  • L
                    lxne Project Sponsor @motdog
                    @motdog It is always a good idea to make a backup of a running system so you can clone it onto a new sd in case.
                    https://beebom.com/how-clone-raspberry-pi-sd-card-windows-linux-macos/
                      retroflex Project Sponsor Module Developer
                      In addition to having a img backup, it’s always a good idea to backup the config file and custom css file.
                      To avoid card corruptions, always SSH into the RPi and perform a sudo shutdown instead of just pulling the plug.
                      S M 2 Replies Last reply
                        sdetweil @retroflex
                        @retroflex i had one card suddenly go read-only…
                          motdog @retroflex
                          @retroflex I used the shutdown from MMM-remotecontrol to shut it down. 8 did have a backup of config & css on laptop so it was just reinstalling modules for the most part
