    Calendar issue 2.8.0 - Repeating events
    9 Posts 7 Posters 3.4k Views 7 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      As of 2.8.0 - Google Calendar Items that repeat are displayed a day early. Non-repeating events are correct.
      This is my office calendar so I can’t share details other than that…
        skippy_oz
        I’m also having the same issue as we work variable shifts we use the Calendar on MM to know when to go to work
        • BKeyportB Offline
          So, I ended up changing to MMM-MyCalendar, because of this.
          The bug appears to be that the “calendar” module is processing repeating events for itself, rather than using the event as I have it, and getting that all wrong.
          For example, I have a monthly meeting (except July) repeated out, with July removed. It shows (on the day before) in July anyway.
            dlindval
            I too have repeating events from Google Calendar that show up on the standard MM Calendar module one day early. One is to occur every Monday at 6:30-8:30 pm, another Wed same 6:30-8:30pm. MM shows them as Sunday and Tuesday.
            I will try MMM-MyCalendar and see if they show up correctly…
              mad mike Project Sponsor
              I also have an issue with my recurring google calendar events. If the recurring event has a start time between 00:01 and 09:59, then the event shows up in the calendar with that start time plus 24hrs. So an Event on Monday at 07:00 will show up in the calendar on Tuesday at 07:00.
              Also all day events start at 20:30. I wonder if this might be causing the time issues.
              The recurring events show correctly with MMM-MyCalendar.
                there is a bug in the default calendar for repeating events.
                so far no-one has had the time to investigate and propose a solution
                  Clubjack @sdetweil
                  Something New here?
                  Have a similar problem with recurring appointments. However, these are not displayed to me one day earlier, but a day later.
                  S evroomE 2 Replies Last reply Reply Quote 0
                    sdetweil @Clubjack
                    @Clubjack sorry, I have not been looking at that problem…
                    • evroomE Offline
                      evroom @Clubjack
                      @Clubjack and others,
                      I noticed this problem too.
                      For instance my birthday lasted 2 days ( only got presents once though) and my wedding-day is one day forward (which will upset my wife).
                      The entries were made using Google Calendar (so not a calendar app that synchronizes with Google).
                      I notice this since 2020, but that does not mean it did not happen before, could have overlooked it.
                      When I ran a test with a dummy entry, it worked fine.
                      When I toggle a „faulty“ entry from repeating to not repeating and then back to repeating, the entry is shown correct.
                      I collected some data and will post it when I sorted it out a bit.
                      MagicMirror version: 2.35.0
                      Test environment:
                      MagicMirror version: 2.36.0-develop
