    Calendar issue 2.8.0 - Repeating events
    9 Posts 7 Posters 3.3k Views 7 Watching
      dlindval
      I too have repeating events from Google Calendar that show up on the standard MM Calendar module one day early. One is to occur every Monday at 6:30-8:30 pm, another Wed same 6:30-8:30pm. MM shows them as Sunday and Tuesday.
      I will try MMM-MyCalendar and see if they show up correctly…
        mad mike Project Sponsor
        I also have an issue with my recurring google calendar events. If the recurring event has a start time between 00:01 and 09:59, then the event shows up in the calendar with that start time plus 24hrs. So an Event on Monday at 07:00 will show up in the calendar on Tuesday at 07:00.
        Also all day events start at 20:30. I wonder if this might be causing the time issues.
        The recurring events show correctly with MMM-MyCalendar.
          there is a bug in the default calendar for repeating events.
          so far no-one has had the time to investigate and propose a solution
            Clubjack @sdetweil
            Something New here?
            Have a similar problem with recurring appointments. However, these are not displayed to me one day earlier, but a day later.
            S evroomE 2 Replies Last reply Reply Quote 0
              sdetweil @Clubjack
              @Clubjack sorry, I have not been looking at that problem…
              • evroomE Offline
                evroom @Clubjack
                @Clubjack and others,
                I noticed this problem too.
                For instance my birthday lasted 2 days ( only got presents once though) and my wedding-day is one day forward (which will upset my wife).
                The entries were made using Google Calendar (so not a calendar app that synchronizes with Google).
                I notice this since 2020, but that does not mean it did not happen before, could have overlooked it.
                When I ran a test with a dummy entry, it worked fine.
                When I toggle a „faulty“ entry from repeating to not repeating and then back to repeating, the entry is shown correct.
                I collected some data and will post it when I sorted it out a bit.
                MagicMirror version: 2.33.0
                Test environment:
                MagicMirror version: v2.33.0
