    MMM-PIR-Sensor with Radar sensor( RCWL-0516)
    6 Posts 3 Posters 2.1k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Hi all,
      I think I’ve read somewhere that MMM-PIR-Sensor works as well with a radar seonsor (RCWL-0516) behind glass.
      Now for me it currently gives very odd behaviour.
      I get a USER_PRESENCE notification and a “refresh” of the monitor (turn off shortly and turn it on again) every few seconds even if noone is in front of the mirror.
      No other messages, no errors.
      I have the radar sensor installed without any resistor in between.
      Nothing special in the config.
              //disabled: true,
              module: 'MMM-PIR-Sensor',
                  sensorPin: 17,
                  powerSavingDelay: 20,
      Can anyone confirm that this module works with a radar sensor and possibly help me out?
      Thanks!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • lavolp3L Offline
        I tweaked the module logging a bit to include the time and there’s obviously something systematic happening. This is what I get after some time (as said, messages included with console.log.:
        It’s always turning on after 1-2 minutes and turning off after 3 seconds immediately.
        After some googling I’m getting the feeling that the radar sensor is not the best way to go…
          MacMirror
          I am using the same sensor even on the same GPIO pin with the module. First it didn’t worked, but after doing an update of the module everything is running like expected.
          Did you connected the sensor correct?
          • lavolp3L Offline
            lavolp3 Module Developer @MacMirror
            @MacMirror
            Checked the pins several times.
            Are you using a resistor or anything in between? Or is it wired directly?
              MacMirror
              The sensor is connected directly.
              Did you wired the Vin to 5V on the Raspi? Don’t use the 3v3-Pin!
                Babene1 Project Sponsor
                Does anyone have a nice housing for the sensor RCWL-0516? Mounting on a wooden frame, such as this one from the PIR
                Thank you
