    MMM-awesome-alexa
    241 Posts 43 Posters 460.5k Views 47 Watching
    • Cr4z33C
      Cr4z33 @sdetweil
      @sdetweil finally I could hear the sound output of Alexa in my mirror!
      However for some reason it plays like if in slow motion. :persevering_face:
        Canterrain @Cr4z33
        @Cr4z33
        Oddly that’s not working for me either. Maybe I’m doing something wrong?
        What should I be using for the Device ID? I’ve been using the product ID, but maybe that’s wrong.
        Cr4z33C 1 Reply Last reply
        • Cr4z33C
          Cr4z33 @Canterrain
          @Canterrain no that is correct. ;)
            Canterrain @Cr4z33
            @Cr4z33
            Well dang. I’m doing something wrong here. Whether I use the helper config or the tool above, I get a broken error page.
            And I know an error page is expected, but it’s not a long url with a code in it.
            It’s like… amazon.com/wpa
            and that’s it.
            Was the right choice “device with alexa built in” and “no companion app” ? I figure I must have done something wrong on the Amazon developer page, since that’s the part with no guide and it’s working for other people.
            M J 2 Replies Last reply
              stalker401
              So does anyone actually have a step by step directions on how to set this up? Sorry i’m a huge noob, and I’m lost (which is probably due to the noob part). I do understand this is a difficult set up, but i’m kind of hoping there might be a detailed guide on this or even a youtube video (including how Amazon Developer should be set up).
              EDIT:
              I’m able to get to the auth request as most people, and I get the error: We’re sorry!
              An error occurred when we tried to process your request. Rest assured, we’re already working on the problem and expect to resolve it shortly.
              I understand this could either by my settings, or something on the amazon side, but has anyone gotten past this recently? Or is there another module I should be using?
                berne
                  berne @dolanmiu
                  @dolanmiu i am done install this, havet test it yet,
                  but i got the code for config.js
                  But i allso got this:
                  Full response from Amazon
                    "_body": "{\"error_description\":\"Client authentication failed\",\"error\":\"invalid_client\"}",
                    "status": 401,
                    "ok": false,
                    "statusText": "Unauthorized",
                    "headers": {
                      "pragma": [
                        "no-cache"
                      "date": [
                        "Mon",
                        " 12 Aug 2019 08:06:35 GMT"
                      "x-amzn-errortype": [
                        "OA2InvalidClientException:http://internal.amazon.com/coral/com.amazon.panda/"
                      "x-amzn-requestid": [
                        "sdsdfgergegegege0e"
                      "content-type": [
                        "application/json;charset=UTF-8"
                      "cache-control": [
                        "no-cache",
                        " no-store",
                        " must-revalidate"
                      "content-length": [
                        "85"
                    "type": 2,
                    "url": "https://api.amazon.com/auth/o2/token"
                  Do i need to do anything with this? or what does this go, and what does i do?
                  Regards
                  P 1 Reply Last reply
                  • QuberchQ
                    Quberch
                    First I’ve to say awesome work @dolanmiu ! I’ve installed as described in your documentation. For auto start I’m still using PM2 with the mm.sh script and can’t get the wake word to trigger. ALSA ist configured and recording. Any ideas what could be the problem? Do I have to get rid completely of PM2? Many thanks in advance for your help!
                      Cordetx
                      Can you please add the wake word “Mirror Mirror On The Wall”?
                      B 1 Reply Last reply
                        berne @Cordetx
                        what mic are people using, i have this: USB MIC
                        but cant get it to work so looking for a new one
                          menanr @Canterrain
                          @Canterrain said in MMM-awesome-alexa:
                          @Cr4z33
                          and that’s it.
                          Hey
                          did you get it working. I am stuck at the same spot.
                            prpun311 @berne
                            @berne No, its just telling you what the amazon site is doing, you only need the top portion.
                              prpun311 @menanr
                              @menanr try this out,
                              https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
                              • Blackhawk50000B
                                Blackhawk50000
                                I would LOVE to get this work… i have done everything that is written in the guide:
                                2nd hand guide
                                and of course in your normal regular guide…
                                i have testet my microphone and my speaker… everything is okay. but when i set up the config and a try tu say something… NOTHING works.
                                even with wireshark i dont see, that everything is trying to do something.
                                • Blackhawk50000B
                                  Blackhawk50000
                                  Okay, little Update, why i think the module dont work.
                                  I saw that the part:
                                  rm -rf node_modules
                                  npm install nan --save
                                  npm install node-pre-gyp@0.12.0 --save
                                  npm install
                                  npm run prepublish
                                  throws some erros:
                                  Found 2 errors.
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! errno 2
                                  npm ERR! snowboy@1.3.1 prepublish: `tsc --listFiles`
                                  npm ERR! Exit status 2
                                  npm ERR!
                                  npm ERR! Failed at the snowboy@1.3.1 prepublish script.
                                  npm ERR!     /home/pi/.npm/_logs/2019-09-11T20_53_08_308Z-debug.log
                                  after a bit googeling i found this: https://www.gitmemory.com/issue/eouia/MMM-Hotword/65/507582634
                                  so i editet the package.json and set up the typescript version ti 3.5.2 and gor this errors by npm run prepublish:
                                  > snowboy@1.3.1 prepublish /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
                                  > tsc --listFiles
                                  node_modules/@types/node/index.d.ts:43:11 - error TS2300: Duplicate identifier 'IteratorResult'.
                                  43 interface IteratorResult<T> { }
                                    node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6
                                      41 type IteratorResult<T, TReturn = any> = IteratorYieldResult<T> | IteratorReturnResult<TReturn>;
                                      'IteratorResult' was also declared here.
                                  node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6 - error TS2300: Duplicate identifier 'IteratorResult'.
                                  i think this is a current problem, that snowboy is not correct installed… can anyone confiorm this?
                                  • H
                                    HabibA
                                    • H
                                      HabibA
                                      I solved my problems with that now.
                                      https://github.com/dolanmiu/MMM-awesome-alexa/issues/184#issuecomment-584215826
                                      • V
                                        vlatko_jordanov
                                        Hi @dolanmiu awesome job with the Alexa I must say!!
                                        I have set it up however I think it’s behaving weird or I am missing some bits and pieces to make it work! I’ve added MMM-NowPlayingOnSpotify and google calendar however when I try to ask Alexa to add event on the calendar or to play Spotify it has no idea, what am I missing here, please let me know what logs I can provide to troubleshoot!
                                        Cheers,
                                        Vlatko
                                          sdetweil @vlatko_jordanov
                                          @vlatko_jordanov said in MMM-awesome-alexa:
                                          this module shows what is playing somewhere else.
                                          I don’t think alexa can start playing anywhere, i stand corrected
                                          https://www.spotify.com/us/amazonalexa/
                                          now to make spotify play ON the PI
                                          https://www.raspberrypi.org/forums/viewtopic.php?t=215857
                                          how to integrate those, I don’t know.
                                          calendar
                                          can alexa add to your google calendar? it doesn’t know anything about what is on the mirror,
                                          and the cal on the mirror is a download from some other location(google, apple…) . (ie , its read only)
                                          https://www.techradar.com/how-to/how-to-connect-your-google-calendar-to-amazon-echo
                                          V 1 Reply Last reply
                                          • V
                                            vlatko_jordanov @sdetweil
                                            Hey Sam!
                                            Thanks for coming coming back on this! Well I must say I was thinking the same that it could be due to something like that and the name of the Spotify module says it all doesn’t it :)
                                            I was tricked by this video on youtube: https://www.youtube.com/watch?v=q7wqm8h3PnA
                                            He didn’t mentioned anywhere how he controls Spotify, so I assumed Alexa somehow knew how to reach spotify and the module just to display the now playing.
                                            So I need client is what you say right?
                                            And about the calendar I already gave alexa rights through the Alexa app on my android phone but the funny thing is that when I go to devices it says that it’s offline?
                                            Cheers,
                                            Vlatko
                                            • 12
                                            • 13
                                            • 4 / 13
