    MMM-awesome-alexa
    241 Posts 43 Posters 460.5k Views 47 Watching
      sdetweil @Cr4z33
      @Cr4z33 said in MMM-awesome-alexa:
      every other module using sound (ie. MMM-AssistantMk2, MMM-Spotify, etc.) is already working perfectly.
      yes, doesn’t mean anything… every module can use their own methods to make sound…
      let us know if/when u get there
      Cr4z33C 2 Replies Last reply
      • Cr4z33C
        Cr4z33 @sdetweil
        @sdetweil sure.
        I might have some spare time later today and I definitely need a working Alexa module ASAP.
        • Cr4z33C
          Cr4z33 @sdetweil
          @sdetweil so I followed the Audio guide, but immediately had to go to the Audio Troubleshooting section because no sound was coming out.
          Created the suggested audio settings file, rebooted, but the module keeps working like in my first post here…
          I am using HDMI output and a USB mic.
          They work perfectly with other modules or ie. with VLC playing.
          Edit
          My fault I didn’t run MM into dev mode so now I notice there’s actually an error when waking up the module, but I don’t know what it means.
          Does anybody have please a clue about what’s written below?
          MMM-awesome-alexa.js:1 Uncaught (in promise) DOMException: play() failed because the user didn't interact with the document first. https://goo.gl/xX8pDD
            yep, not your fault… new browser restriction…
            fix in next version july
            workaround
            edit
            MagicMirror/js/electron.js
            add the line marked below
            let mainWindow;
            function createWindow() {
                app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
            save, and restart Mm
            • Cr4z33C
              Cr4z33 @sdetweil
              @sdetweil cheers going to try it now! :thumbs_up_medium_skin_tone:
                Canterrain @Canterrain
                @Canterrain said in MMM-awesome-alexa:
                Trying to finish setup of the module.
                I’m in the helper config, and when I get to the point of supplying a return URL I enter:
                https://localhost:3000/authresponse
                But terminal tells me that’s an invalid URL.
                I’ve put https://localhost:3000/authresponse as my return URL and https://localhost:3000/ as my authorized URL on the Amazon developer site. What I am I doing wrong here?
                Bump on this question, still can’t get past the local url section. Any help would be appreciated.
                Cr4z33C 1 Reply Last reply
                • Cr4z33C
                  Cr4z33 @Canterrain
                  @Canterrain follow this guide.
                  It worked for me.
                  • Cr4z33C
                    Cr4z33 @sdetweil
                    @sdetweil finally I could hear the sound output of Alexa in my mirror!
                    However for some reason it plays like if in slow motion. :persevering_face:
                      Canterrain @Cr4z33
                      @Cr4z33
                      Oddly that’s not working for me either. Maybe I’m doing something wrong?
                      What should I be using for the Device ID? I’ve been using the product ID, but maybe that’s wrong.
                      • Cr4z33C
                        Cr4z33 @Canterrain
                        @Canterrain no that is correct. ;)
                          Canterrain @Cr4z33
                          @Cr4z33
                          Well dang. I’m doing something wrong here. Whether I use the helper config or the tool above, I get a broken error page.
                          And I know an error page is expected, but it’s not a long url with a code in it.
                          It’s like… amazon.com/wpa
                          and that’s it.
                          Was the right choice “device with alexa built in” and “no companion app” ? I figure I must have done something wrong on the Amazon developer page, since that’s the part with no guide and it’s working for other people.
                          M J 2 Replies Last reply
                            stalker401
                            So does anyone actually have a step by step directions on how to set this up? Sorry i’m a huge noob, and I’m lost (which is probably due to the noob part). I do understand this is a difficult set up, but i’m kind of hoping there might be a detailed guide on this or even a youtube video (including how Amazon Developer should be set up).
                            EDIT:
                            I’m able to get to the auth request as most people, and I get the error: We’re sorry!
                            An error occurred when we tried to process your request. Rest assured, we’re already working on the problem and expect to resolve it shortly.
                            I understand this could either by my settings, or something on the amazon side, but has anyone gotten past this recently? Or is there another module I should be using?
                              berne
                                berne @dolanmiu
                                @dolanmiu i am done install this, havet test it yet,
                                but i got the code for config.js
                                But i allso got this:
                                Full response from Amazon
                                  "_body": "{\"error_description\":\"Client authentication failed\",\"error\":\"invalid_client\"}",
                                  "status": 401,
                                  "ok": false,
                                  "statusText": "Unauthorized",
                                  "headers": {
                                    "pragma": [
                                      "no-cache"
                                    "date": [
                                      "Mon",
                                      " 12 Aug 2019 08:06:35 GMT"
                                    "x-amzn-errortype": [
                                      "OA2InvalidClientException:http://internal.amazon.com/coral/com.amazon.panda/"
                                    "x-amzn-requestid": [
                                      "sdsdfgergegegege0e"
                                    "content-type": [
                                      "application/json;charset=UTF-8"
                                    "cache-control": [
                                      "no-cache",
                                      " no-store",
                                      " must-revalidate"
                                    "content-length": [
                                      "85"
                                  "type": 2,
                                  "url": "https://api.amazon.com/auth/o2/token"
                                Do i need to do anything with this? or what does this go, and what does i do?
                                Regards
                                P 1 Reply Last reply
                                • QuberchQ
                                  Quberch
                                  First I’ve to say awesome work @dolanmiu ! I’ve installed as described in your documentation. For auto start I’m still using PM2 with the mm.sh script and can’t get the wake word to trigger. ALSA ist configured and recording. Any ideas what could be the problem? Do I have to get rid completely of PM2? Many thanks in advance for your help!
                                    Cordetx
                                    Can you please add the wake word “Mirror Mirror On The Wall”?
                                    B 1 Reply Last reply
                                      berne @Cordetx
                                      what mic are people using, i have this: USB MIC
                                      but cant get it to work so looking for a new one
                                        menanr @Canterrain
                                        @Cr4z33
                                        and that’s it.
                                        Hey
                                        did you get it working. I am stuck at the same spot.
                                          prpun311 @berne
                                          @berne No, its just telling you what the amazon site is doing, you only need the top portion.
                                            prpun311 @menanr
                                            @menanr try this out,
                                            https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
                                            • 12
                                            • 13
                                            • 4 / 13
