    MMM-awesome-alexa
    241 Posts 43 Posters 452.0k Views 47 Watching
      yep, not your fault… new browser restriction…
      fix in next version july
      workaround
      edit
      MagicMirror/js/electron.js
      add the line marked below
      let mainWindow;
      function createWindow() {
          app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
      save, and restart Mm
      Cr4z33C 2 Replies Last reply Reply Quote 0
      • Cr4z33C
        Cr4z33 @sdetweil
        @sdetweil cheers going to try it now! :thumbs_up_medium_skin_tone:
          Canterrain @Canterrain
          @Canterrain said in MMM-awesome-alexa:
          Trying to finish setup of the module.
          I’m in the helper config, and when I get to the point of supplying a return URL I enter:
          https://localhost:3000/authresponse
          But terminal tells me that’s an invalid URL.
          I’ve put https://localhost:3000/authresponse as my return URL and https://localhost:3000/ as my authorized URL on the Amazon developer site. What I am I doing wrong here?
          Bump on this question, still can’t get past the local url section. Any help would be appreciated.
          • Cr4z33C
            Cr4z33 @Canterrain
            @Canterrain follow this guide.
            It worked for me.
            • Cr4z33C
              Cr4z33 @sdetweil
              @sdetweil finally I could hear the sound output of Alexa in my mirror!
              However for some reason it plays like if in slow motion. :persevering_face:
                Canterrain @Cr4z33
                @Cr4z33
                Oddly that’s not working for me either. Maybe I’m doing something wrong?
                What should I be using for the Device ID? I’ve been using the product ID, but maybe that’s wrong.
                • Cr4z33C
                  Cr4z33 @Canterrain
                  @Canterrain no that is correct. ;)
                    Canterrain @Cr4z33
                    @Cr4z33
                    Well dang. I’m doing something wrong here. Whether I use the helper config or the tool above, I get a broken error page.
                    And I know an error page is expected, but it’s not a long url with a code in it.
                    It’s like… amazon.com/wpa
                    and that’s it.
                    Was the right choice “device with alexa built in” and “no companion app” ? I figure I must have done something wrong on the Amazon developer page, since that’s the part with no guide and it’s working for other people.
                    M J 2 Replies Last reply Reply Quote 0
                      stalker401
                      So does anyone actually have a step by step directions on how to set this up? Sorry i’m a huge noob, and I’m lost (which is probably due to the noob part). I do understand this is a difficult set up, but i’m kind of hoping there might be a detailed guide on this or even a youtube video (including how Amazon Developer should be set up).
                      EDIT:
                      I’m able to get to the auth request as most people, and I get the error: We’re sorry!
                      An error occurred when we tried to process your request. Rest assured, we’re already working on the problem and expect to resolve it shortly.
                      I understand this could either by my settings, or something on the amazon side, but has anyone gotten past this recently? Or is there another module I should be using?
                        berne
                          berne @dolanmiu
                          @dolanmiu i am done install this, havet test it yet,
                          but i got the code for config.js
                          But i allso got this:
                          Full response from Amazon
                            "_body": "{\"error_description\":\"Client authentication failed\",\"error\":\"invalid_client\"}",
                            "status": 401,
                            "ok": false,
                            "statusText": "Unauthorized",
                            "headers": {
                              "pragma": [
                                "no-cache"
                              "date": [
                                "Mon",
                                " 12 Aug 2019 08:06:35 GMT"
                              "x-amzn-errortype": [
                                "OA2InvalidClientException:http://internal.amazon.com/coral/com.amazon.panda/"
                              "x-amzn-requestid": [
                                "sdsdfgergegegege0e"
                              "content-type": [
                                "application/json;charset=UTF-8"
                              "cache-control": [
                                "no-cache",
                                " no-store",
                                " must-revalidate"
                              "content-length": [
                                "85"
                            "type": 2,
                            "url": "https://api.amazon.com/auth/o2/token"
                          Do i need to do anything with this? or what does this go, and what does i do?
                          Regards
                          • QuberchQ
                            Quberch
                            First I’ve to say awesome work @dolanmiu ! I’ve installed as described in your documentation. For auto start I’m still using PM2 with the mm.sh script and can’t get the wake word to trigger. ALSA ist configured and recording. Any ideas what could be the problem? Do I have to get rid completely of PM2? Many thanks in advance for your help!
                              Cordetx
                              Can you please add the wake word “Mirror Mirror On The Wall”?
                                berne @Cordetx
                                what mic are people using, i have this: USB MIC
                                but cant get it to work so looking for a new one
                                  menanr @Canterrain
                                  @Cr4z33
                                  and that’s it.
                                  Hey
                                  did you get it working. I am stuck at the same spot.
                                    prpun311 @berne
                                    @berne No, its just telling you what the amazon site is doing, you only need the top portion.
                                      prpun311 @menanr
                                      @menanr try this out,
                                      https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
                                      • Blackhawk50000B
                                        Blackhawk50000
                                        I would LOVE to get this work… i have done everything that is written in the guide:
                                        2nd hand guide
                                        and of course in your normal regular guide…
                                        i have testet my microphone and my speaker… everything is okay. but when i set up the config and a try tu say something… NOTHING works.
                                        even with wireshark i dont see, that everything is trying to do something.
                                        • Blackhawk50000B
                                          Blackhawk50000
                                          Okay, little Update, why i think the module dont work.
                                          I saw that the part:
                                          rm -rf node_modules
                                          npm install nan --save
                                          npm install node-pre-gyp@0.12.0 --save
                                          npm install
                                          npm run prepublish
                                          throws some erros:
                                          Found 2 errors.
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 2
                                          npm ERR! snowboy@1.3.1 prepublish: `tsc --listFiles`
                                          npm ERR! Exit status 2
                                          npm ERR!
                                          npm ERR! Failed at the snowboy@1.3.1 prepublish script.
                                          npm ERR!     /home/pi/.npm/_logs/2019-09-11T20_53_08_308Z-debug.log
                                          after a bit googeling i found this: https://www.gitmemory.com/issue/eouia/MMM-Hotword/65/507582634
                                          so i editet the package.json and set up the typescript version ti 3.5.2 and gor this errors by npm run prepublish:
                                          > snowboy@1.3.1 prepublish /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
                                          > tsc --listFiles
                                          node_modules/@types/node/index.d.ts:43:11 - error TS2300: Duplicate identifier 'IteratorResult'.
                                          43 interface IteratorResult<T> { }
                                            node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6
                                              41 type IteratorResult<T, TReturn = any> = IteratorYieldResult<T> | IteratorReturnResult<TReturn>;
                                              'IteratorResult' was also declared here.
                                          node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6 - error TS2300: Duplicate identifier 'IteratorResult'.
                                          i think this is a current problem, that snowboy is not correct installed… can anyone confiorm this?
                                          • H
                                            HabibA
                                            • 12
                                            • 13
                                            • 4 / 13
