    MMM-awesome-alexa
    241 Posts 43 Posters 460.8k Views 47 Watching
      stalker401
      So does anyone actually have a step by step directions on how to set this up? Sorry i’m a huge noob, and I’m lost (which is probably due to the noob part). I do understand this is a difficult set up, but i’m kind of hoping there might be a detailed guide on this or even a youtube video (including how Amazon Developer should be set up).
      EDIT:
      I’m able to get to the auth request as most people, and I get the error: We’re sorry!
      An error occurred when we tried to process your request. Rest assured, we’re already working on the problem and expect to resolve it shortly.
      I understand this could either by my settings, or something on the amazon side, but has anyone gotten past this recently? Or is there another module I should be using?
        berne
          berne @dolanmiu
          @dolanmiu i am done install this, havet test it yet,
          but i got the code for config.js
          But i allso got this:
          Full response from Amazon
            "_body": "{\"error_description\":\"Client authentication failed\",\"error\":\"invalid_client\"}",
            "status": 401,
            "ok": false,
            "statusText": "Unauthorized",
            "headers": {
              "pragma": [
                "no-cache"
              "date": [
                "Mon",
                " 12 Aug 2019 08:06:35 GMT"
              "x-amzn-errortype": [
                "OA2InvalidClientException:http://internal.amazon.com/coral/com.amazon.panda/"
              "x-amzn-requestid": [
                "sdsdfgergegegege0e"
              "content-type": [
                "application/json;charset=UTF-8"
              "cache-control": [
                "no-cache",
                " no-store",
                " must-revalidate"
              "content-length": [
                "85"
            "type": 2,
            "url": "https://api.amazon.com/auth/o2/token"
          Do i need to do anything with this? or what does this go, and what does i do?
          Regards
          P 1 Reply Last reply
          • QuberchQ
            Quberch
            First I’ve to say awesome work @dolanmiu ! I’ve installed as described in your documentation. For auto start I’m still using PM2 with the mm.sh script and can’t get the wake word to trigger. ALSA ist configured and recording. Any ideas what could be the problem? Do I have to get rid completely of PM2? Many thanks in advance for your help!
              Cordetx
              Can you please add the wake word “Mirror Mirror On The Wall”?
              B 1 Reply Last reply
                berne @Cordetx
                what mic are people using, i have this: USB MIC
                but cant get it to work so looking for a new one
                  menanr @Canterrain
                  @Canterrain said in MMM-awesome-alexa:
                  @Cr4z33
                  Well dang. I’m doing something wrong here. Whether I use the helper config or the tool above, I get a broken error page.
                  And I know an error page is expected, but it’s not a long url with a code in it.
                  It’s like… amazon.com/wpa
                  and that’s it.
                  Was the right choice “device with alexa built in” and “no companion app” ? I figure I must have done something wrong on the Amazon developer page, since that’s the part with no guide and it’s working for other people.
                  Hey
                  did you get it working. I am stuck at the same spot.
                    prpun311 @berne
                    @berne No, its just telling you what the amazon site is doing, you only need the top portion.
                      prpun311 @menanr
                      @menanr try this out,
                      https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/
                      • Blackhawk50000B
                        Blackhawk50000
                        I would LOVE to get this work… i have done everything that is written in the guide:
                        2nd hand guide
                        and of course in your normal regular guide…
                        i have testet my microphone and my speaker… everything is okay. but when i set up the config and a try tu say something… NOTHING works.
                        even with wireshark i dont see, that everything is trying to do something.
                        • Blackhawk50000B
                          Blackhawk50000
                          Okay, little Update, why i think the module dont work.
                          I saw that the part:
                          rm -rf node_modules
                          npm install nan --save
                          npm install node-pre-gyp@0.12.0 --save
                          npm install
                          npm run prepublish
                          throws some erros:
                          Found 2 errors.
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 2
                          npm ERR! snowboy@1.3.1 prepublish: `tsc --listFiles`
                          npm ERR! Exit status 2
                          npm ERR!
                          npm ERR! Failed at the snowboy@1.3.1 prepublish script.
                          npm ERR!     /home/pi/.npm/_logs/2019-09-11T20_53_08_308Z-debug.log
                          after a bit googeling i found this: https://www.gitmemory.com/issue/eouia/MMM-Hotword/65/507582634
                          so i editet the package.json and set up the typescript version ti 3.5.2 and gor this errors by npm run prepublish:
                          > snowboy@1.3.1 prepublish /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
                          > tsc --listFiles
                          node_modules/@types/node/index.d.ts:43:11 - error TS2300: Duplicate identifier 'IteratorResult'.
                          43 interface IteratorResult<T> { }
                            node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6
                              41 type IteratorResult<T, TReturn = any> = IteratorYieldResult<T> | IteratorReturnResult<TReturn>;
                              'IteratorResult' was also declared here.
                          node_modules/typescript/lib/lib.es2015.iterable.d.ts:41:6 - error TS2300: Duplicate identifier 'IteratorResult'.
                          i think this is a current problem, that snowboy is not correct installed… can anyone confiorm this?
                          • H
                            HabibA
                            • H
                              HabibA
                              I solved my problems with that now.
                              https://github.com/dolanmiu/MMM-awesome-alexa/issues/184#issuecomment-584215826
                              • V
                                vlatko_jordanov
                                Hi @dolanmiu awesome job with the Alexa I must say!!
                                I have set it up however I think it’s behaving weird or I am missing some bits and pieces to make it work! I’ve added MMM-NowPlayingOnSpotify and google calendar however when I try to ask Alexa to add event on the calendar or to play Spotify it has no idea, what am I missing here, please let me know what logs I can provide to troubleshoot!
                                Cheers,
                                Vlatko
                                  sdetweil @vlatko_jordanov
                                  @vlatko_jordanov said in MMM-awesome-alexa:
                                  this module shows what is playing somewhere else.
                                  I don’t think alexa can start playing anywhere, i stand corrected
                                  https://www.spotify.com/us/amazonalexa/
                                  now to make spotify play ON the PI
                                  https://www.raspberrypi.org/forums/viewtopic.php?t=215857
                                  how to integrate those, I don’t know.
                                  calendar
                                  can alexa add to your google calendar? it doesn’t know anything about what is on the mirror,
                                  and the cal on the mirror is a download from some other location(google, apple…) . (ie , its read only)
                                  https://www.techradar.com/how-to/how-to-connect-your-google-calendar-to-amazon-echo
                                  V 1 Reply Last reply
                                  • V
                                    vlatko_jordanov @sdetweil
                                    Hey Sam!
                                    Thanks for coming coming back on this! Well I must say I was thinking the same that it could be due to something like that and the name of the Spotify module says it all doesn’t it :)
                                    I was tricked by this video on youtube: https://www.youtube.com/watch?v=q7wqm8h3PnA
                                    He didn’t mentioned anywhere how he controls Spotify, so I assumed Alexa somehow knew how to reach spotify and the module just to display the now playing.
                                    So I need client is what you say right?
                                    And about the calendar I already gave alexa rights through the Alexa app on my android phone but the funny thing is that when I go to devices it says that it’s offline?
                                    Cheers,
                                    Vlatko
                                      here is how to control potify with alexa, https://www.spotify.com/us/amazonalexa/, unrelated to mirror
                                      So I need client is what you say right? if u want to PLAY on mirror system yes,
                                      rights to what? again, the local ‘calendar’ is a read only copy of a cal somewhere else…
                                      maybe on google?
                                      offline? that is between alexa account(cloud) and google (cloud)
                                      has nothing to do with mirror app
                                      I rechecked and resynched my google calendar with my alexa account…
                                      and then using my echo asked alexa to add an event to my calendar and it worked and shows on the mirror calendar display…
                                        @vlatko_jordanov I am trying to set this up but my brain cannot figure out what I am supposed to put in as the return url in the AVS setup…
                                        my device is not known outside my home.
                                        i can use my public url redirect to make it known
                                        localhost doesn’t work
                                        my public return url DOES get a callback into my browser, but there is no ‘web page’ served at that url… so it ‘times out’…
                                        the setup app doesn’t use request to MAKE a web server there… (I have had to do this on other oauth apps…)
                                        edit: DOAH… read the instructions!!! lol… it is EPEXCTED to FAIL to connect… read the text from the failing url
                                        got that… BUT then next step fails for me…
                                         Enter your Authorization code (from previous step): ANMJShcLPpSKjJkKLbzj
                                          ◡ Getting response from Amazon...(node:2772) UnhandledPromiseRejectionWarning: StatusCodeError: 400 - {"error_description":"The request has an invalid grant parameter : code","error":"invalid_grant"}
                                        V B 2 Replies Last reply
                                        • V
                                          Hi Sam,
                                          Alright that’s cool I think I’ve put my question wrong, is it possible to have the mmm-awesome-alexa (standalone app) linked with alexa(cloud) without owning any amazon echo dot in my household i.e. the rapsi to be my first and only device with the awesome-alexa module? :)
                                          I did heard that from a friend that his echo dot couldn’t be seen from the WAN side but he could still drop in and announce messages to it which I believe is using different callback settings/ports than the actual device communication, haven’t gone into details as yourself but that’s good to know :)
                                          Thanks,
                                          Vlatko
                                            @vlatko_jordanov sorry. I do not know if u can have mirror BE a full function Alexa node. It seems that should be possible, as I have an automobile Alexa.
                                            Now, can this module do all that?
                                            Don’t know
                                            • 12
                                            • 13
                                            • 4 / 13
