    Blank mm after update
    48 Posts 4 Posters 25.4k Views 4 Watching
      sdetweil @kvicksson
      @kvicksson the rules are text needs quotes (’ or " matching)
      numbers and true/false should NOT have quotes… as they become strings and not numeric or logical values
      if variable == true will fail with quoted values…
      • evroomE Offline
        evroom @lavolp3
        @lavolp3 said in Blank mm after update:
        well with the config:check he would not have found the error, would he?
        In this case perhaps not, but it cannot hurt to run it in order to exclude error(s) before and after this part of the config.
        Normally a 'true' versus true would not cause a black screen, but I might be wrong.
        And a trouble shooting guide would have to start with the config:checkIMHO.
        MagicMirror version: 2.37.0
          sdetweil @evroom
          @evroom said in Blank mm after update:
          Normally a ‘true’ versus true would not cause a black screen
          u don’t know how the module code might fail…
          which is what causes the blackscreen to begin with
          • evroomE Offline
            evroom
            @sdetweil said in Blank mm after update:
            Tried the module myself.
            https://github.com/paphko/mmm-weatherchart
            pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 100
            0|mm       | Starting MagicMirror ...
            0|mm       |
            0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
            0|mm       | > sh run-start.sh
            0|mm       |
            0|mm       | Starting MagicMirror: v2.8.0
            0|mm       | Loading config ...
            0|mm       | Loading module helpers ...
            0|mm       | No helper found for module: alert.
            0|mm       | Initializing new module helper ...
            0|mm       | Module helper loaded: updatenotification
            0|mm       | Whoops! There was an uncaught exception...
            0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|mm  | Launching application.
            Indeed a black screen.
            Now how to help the girl from Stråvalla ?
              sdetweil @evroom
              0|mm | Initializing new module helper …
              0|mm | Loading module helpers …
              0|mm | Whoops! There was an uncaught exception…
              seems odd that there would be two invocations of these modules…
              but as a test, in MagicMirror/config/config.js add
                  disabled: true,
              to both those modules, and restart mm and see what happens
                missing a required node package ‘del’
                no package.json to inform the user
                  warning, warning… copy and save
                  MagicMirror/modules/node_modules/node_helper (folder, which contains index.js)
                  then
                  cd ~/MagicMirror/modules/mmm-weatherchart
                  npm install del
                  check for a missing
                  MagicMirror/modules/node_modules/node_helper folder
                  and if so, copy it back
                  i opened an issue with mmm-weatherchart
                  • evroomE Offline
                    evroom
                    I have only one mmm-weatherchart module present.
                    When disabled everything is fine.
                    However, I forgot to remove the single quotes, as I just copy/pasted the config from the thread.
                    Corrected it, but now I get even stronger things.
                    0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                    I do not have any string with ‘del’ in my config :worried_face:
                      sdetweil @evroom
                      @evroom see my prior most about the missing module
                      • evroomE Offline
                        evroom
                        I was typing while you answered.
                        Will have a look at it and try it out.
                        • evroomE Offline
                          evroom
                          The module is running now, but I get this error:
                          0|mm  | Downloading weather map with signal: FETCH_MAP From URL: www.yr.no/place/Germany/Bavaria/Nuremberg/meteogram.png
                          0|mm  | Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.png'
                          pi@raspberrypi:~/MagicMirror/modules/mmm-weatherchart $ ll /home/pi/MagicMirror/modules/mmm-weatherchart/cache
                          total 12
                          4 drwxr-xr-x 2 pi pi 4096 Aug 29 18:49 .
                          4 drwxr-xr-x 4 pi pi 4096 Aug 29 18:44 ..
                          4 -rw-r--r-- 1 pi pi    6 Aug 29 18:44 .gitignore
                          Then I read somewhere there is a clone of this module that is more recent, so I tried that:
                          https://github.com/szech/mmm-weatherchart
                          Same result: module runs but no file in the cache dir.
                          When opening the URL in the browser, it does show the picture that I do not see on my screen.
                          Oh boy/girl, thought it was a simple syntax thingy in config.js …
                            the module doesn’t work, but doesn’t kill MagicMirror anymore…
                            • evroomE Offline
                              evroom
                              Correct.
                              I have a few questions.
                              In the original module there is no package.json file, where in the cloned one there is.
                              So, when using the original module, you should NOT use npm install, right ?
                              First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
                              When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
                              No harm is done to the node_helper dir.
                              Or is it all BS I am telling here (and made the wrong observations) ??
                                sdetweil @evroom
                                @evroom i cloned and got no package.json
                                i cloned this
                                  sdetweil @evroom
                                  @evroom yes, to all your observations…
                                  • evroomE Offline
                                    evroom
                                    When I use
                                    $ git clone https://github.com/szech/mmm-weatherchart.git
                                    then it works.
                                    The README.md from szech point to papkto.
                                    When corrected and doing npm install in the mmm-weatherchart directory, it works
                                      sdetweil @evroom
                                      @evroom yes, that module has it…
                                      • K Offline
                                        kvicksson @sdetweil
                                        @sdetweil Thanks! This worked for me as it doesn’t kill it anymore. Hope for a quick fix. Can I follow the process somewhere?
                                        S evroomE 3 Replies Last reply Reply Quote 0
                                        • evroomE Offline
                                          evroom
                                          Hi @kvicksson ,
                                          To me it seems there are 3 problems here.
                                          You could have a look what the pm2 log says:
                                          You will either have:
                                          or:
                                          or something completely different.
                                          The 3 problems and potential solutions:
                                          You’re config.js entries:
                                          updateInterval: '3600000',
                                          hideBorder: 'true'
                                          should be:
                                          updateInterval: 3600000,
                                          hideBorder: true
                                          even if the module could potentially handle it.
                                          If your mmm-weatherchart instal has this file present:
                                          /home/pi/MagicMirror/modules/mmm-weatherchart/package.json
                                          then you should run:
                                          $ cd /home/pi/MagicMirror/modules/mmm-weatherchart/
                                          $ npm install
                                          If your mmm-weatherchart instal has this file NOT present:
                                          then you should NOT run npm instal, has it will cause havoc to you MagicMirror install.
                                          I would do this in this situation:
                                          $ mv mmm-weatherchart mmm-weatherchart.saved
                                          $ npm install
                                          $ pm2 restart pm2
                                          When it works:
                                          $ rm -rf mmm-weatherchart.saved
                                          Good luck !!
                                          PS @sdetweil : please comment if I am wrong or made mistakes somewhere & thanks for your input.
                                          S K 2 Replies Last reply Reply Quote 0
                                            sdetweil @kvicksson
                                            @kvicksson said in Blank mm after update:
                                            this is all volunteer… you could post an issue to the module owners github repo… maybe he or someone else will respond… I am like you, just another user…
