    Blank mm after update
    48 Posts 4 Posters 24.2k Views 4 Watching
    • K Offline
      kvicksson
      Just to be clear, I’m a girl… ;)
      The module worked as a charm before the update. So you think I should just skip the apostrophe on the updateInterval and hideBorder?
        sdetweil @kvicksson
        @kvicksson ok… before the update it worked…
        does the module contain a package.json file?
        if so you must also run npm install in the module folder as the version of electron changed in 2.8.0
        in the future, i hope my update script will help solve these problems…
        see
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
          sdetweil @kvicksson
          @kvicksson the rules are text needs quotes (’ or " matching)
          numbers and true/false should NOT have quotes… as they become strings and not numeric or logical values
          if variable == true will fail with quoted values…
          • evroomE Offline
            evroom @lavolp3
            @lavolp3 said in Blank mm after update:
            well with the config:check he would not have found the error, would he?
            In this case perhaps not, but it cannot hurt to run it in order to exclude error(s) before and after this part of the config.
            Normally a 'true' versus true would not cause a black screen, but I might be wrong.
            And a trouble shooting guide would have to start with the config:checkIMHO.
            MagicMirror version: 2.37.0
              sdetweil @evroom
              @evroom said in Blank mm after update:
              Normally a ‘true’ versus true would not cause a black screen
              u don’t know how the module code might fail…
              which is what causes the blackscreen to begin with
              • evroomE Offline
                evroom
                @sdetweil said in Blank mm after update:
                Tried the module myself.
                https://github.com/paphko/mmm-weatherchart
                pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 100
                0|mm       | Starting MagicMirror ...
                0|mm       |
                0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                0|mm       | > sh run-start.sh
                0|mm       |
                0|mm       | Starting MagicMirror: v2.8.0
                0|mm       | Loading config ...
                0|mm       | Loading module helpers ...
                0|mm       | No helper found for module: alert.
                0|mm       | Initializing new module helper ...
                0|mm       | Module helper loaded: updatenotification
                0|mm       | Whoops! There was an uncaught exception...
                0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm  | Launching application.
                Indeed a black screen.
                Now how to help the girl from Stråvalla ?
                  sdetweil @evroom
                  0|mm | Initializing new module helper …
                  0|mm | Loading module helpers …
                  0|mm | Whoops! There was an uncaught exception…
                  seems odd that there would be two invocations of these modules…
                  but as a test, in MagicMirror/config/config.js add
                      disabled: true,
                  to both those modules, and restart mm and see what happens
                    missing a required node package ‘del’
                    no package.json to inform the user
                      warning, warning… copy and save
                      MagicMirror/modules/node_modules/node_helper (folder, which contains index.js)
                      then
                      cd ~/MagicMirror/modules/mmm-weatherchart
                      npm install del
                      check for a missing
                      MagicMirror/modules/node_modules/node_helper folder
                      and if so, copy it back
                      i opened an issue with mmm-weatherchart
                      • evroomE Offline
                        evroom
                        I have only one mmm-weatherchart module present.
                        When disabled everything is fine.
                        However, I forgot to remove the single quotes, as I just copy/pasted the config from the thread.
                        Corrected it, but now I get even stronger things.
                        0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                        I do not have any string with ‘del’ in my config :worried_face:
                          sdetweil @evroom
                          @evroom see my prior most about the missing module
                          • evroomE Offline
                            evroom
                            I was typing while you answered.
                            Will have a look at it and try it out.
                            • evroomE Offline
                              evroom
                              The module is running now, but I get this error:
                              0|mm  | Downloading weather map with signal: FETCH_MAP From URL: www.yr.no/place/Germany/Bavaria/Nuremberg/meteogram.png
                              0|mm  | Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.png'
                              pi@raspberrypi:~/MagicMirror/modules/mmm-weatherchart $ ll /home/pi/MagicMirror/modules/mmm-weatherchart/cache
                              total 12
                              4 drwxr-xr-x 2 pi pi 4096 Aug 29 18:49 .
                              4 drwxr-xr-x 4 pi pi 4096 Aug 29 18:44 ..
                              4 -rw-r--r-- 1 pi pi    6 Aug 29 18:44 .gitignore
                              Then I read somewhere there is a clone of this module that is more recent, so I tried that:
                              https://github.com/szech/mmm-weatherchart
                              Same result: module runs but no file in the cache dir.
                              When opening the URL in the browser, it does show the picture that I do not see on my screen.
                              Oh boy/girl, thought it was a simple syntax thingy in config.js …
                                the module doesn’t work, but doesn’t kill MagicMirror anymore…
                                • evroomE Offline
                                  evroom
                                  Correct.
                                  I have a few questions.
                                  In the original module there is no package.json file, where in the cloned one there is.
                                  So, when using the original module, you should NOT use npm install, right ?
                                  First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
                                  When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
                                  No harm is done to the node_helper dir.
                                  Or is it all BS I am telling here (and made the wrong observations) ??
                                    sdetweil @evroom
                                    @evroom i cloned and got no package.json
                                    i cloned this
                                      sdetweil @evroom
                                      @evroom yes, to all your observations…
                                      • evroomE Offline
                                        evroom
                                        When I use
                                        $ git clone https://github.com/szech/mmm-weatherchart.git
                                        then it works.
                                        The README.md from szech point to papkto.
                                        When corrected and doing npm install in the mmm-weatherchart directory, it works
                                          sdetweil @evroom
                                          @evroom yes, that module has it…
                                          • K Offline
                                            kvicksson @sdetweil
                                            @sdetweil Thanks! This worked for me as it doesn’t kill it anymore. Hope for a quick fix. Can I follow the process somewhere?
                                            S evroomE 3 Replies Last reply Reply Quote 0
