    Blank mm after update
    48 Posts 4 Posters 26.0k Views 4 Watching
    • evroomE
      evroom
      @sdetweil said in Blank mm after update:
      which is what causes the blackscreen to begin with
      Tried the module myself.
      https://github.com/paphko/mmm-weatherchart
      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 100
      0|mm       | Starting MagicMirror ...
      0|mm       |
      0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
      0|mm       | > sh run-start.sh
      0|mm       |
      0|mm       | Starting MagicMirror: v2.8.0
      0|mm       | Loading config ...
      0|mm       | Loading module helpers ...
      0|mm       | No helper found for module: alert.
      0|mm       | Initializing new module helper ...
      0|mm       | Module helper loaded: updatenotification
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm  | Launching application.
      Indeed a black screen.
      Now how to help the girl from Stråvalla ?
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom said in Blank mm after update:
        0|mm | Initializing new module helper …
        0|mm | Loading module helpers …
        0|mm | Whoops! There was an uncaught exception…
        seems odd that there would be two invocations of these modules…
        but as a test, in MagicMirror/config/config.js add
            disabled: true,
        to both those modules, and restart mm and see what happens
          missing a required node package ‘del’
          no package.json to inform the user
            warning, warning… copy and save
            MagicMirror/modules/node_modules/node_helper (folder, which contains index.js)
            then
            cd ~/MagicMirror/modules/mmm-weatherchart
            npm install del
            check for a missing
            MagicMirror/modules/node_modules/node_helper folder
            and if so, copy it back
            i opened an issue with mmm-weatherchart
            K 1 Reply Last reply
            • evroomE
              evroom
              I have only one mmm-weatherchart module present.
              When disabled everything is fine.
              However, I forgot to remove the single quotes, as I just copy/pasted the config from the thread.
              Corrected it, but now I get even stronger things.
              0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
              I do not have any string with ‘del’ in my config :worried_face:
                sdetweil @evroom
                @evroom see my prior most about the missing module
                • evroomE
                  evroom
                  I was typing while you answered.
                  Will have a look at it and try it out.
                  • evroomE
                    evroom
                    The module is running now, but I get this error:
                    0|mm  | Downloading weather map with signal: FETCH_MAP From URL: www.yr.no/place/Germany/Bavaria/Nuremberg/meteogram.png
                    0|mm  | Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.png'
                    pi@raspberrypi:~/MagicMirror/modules/mmm-weatherchart $ ll /home/pi/MagicMirror/modules/mmm-weatherchart/cache
                    total 12
                    4 drwxr-xr-x 2 pi pi 4096 Aug 29 18:49 .
                    4 drwxr-xr-x 4 pi pi 4096 Aug 29 18:44 ..
                    4 -rw-r--r-- 1 pi pi    6 Aug 29 18:44 .gitignore
                    Then I read somewhere there is a clone of this module that is more recent, so I tried that:
                    https://github.com/szech/mmm-weatherchart
                    Same result: module runs but no file in the cache dir.
                    When opening the URL in the browser, it does show the picture that I do not see on my screen.
                    Oh boy/girl, thought it was a simple syntax thingy in config.js …
                      the module doesn’t work, but doesn’t kill MagicMirror anymore…
                      • evroomE
                        evroom
                        Correct.
                        I have a few questions.
                        In the original module there is no package.json file, where in the cloned one there is.
                        So, when using the original module, you should NOT use npm install, right ?
                        First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
                        When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
                        No harm is done to the node_helper dir.
                        Or is it all BS I am telling here (and made the wrong observations) ??
                        S 2 Replies Last reply
                          sdetweil @evroom
                          @evroom i cloned and got no package.json
                          i cloned this
                            sdetweil @evroom
                            @evroom yes, to all your observations…
                            • evroomE
                              evroom
                              When I use
                              $ git clone https://github.com/szech/mmm-weatherchart.git
                              then it works.
                              The README.md from szech point to papkto.
                              When corrected and doing npm install in the mmm-weatherchart directory, it works
                                sdetweil @evroom
                                @evroom yes, that module has it…
                                • K
                                  kvicksson @sdetweil
                                  @sdetweil Thanks! This worked for me as it doesn’t kill it anymore. Hope for a quick fix. Can I follow the process somewhere?
                                  S evroomE 3 Replies Last reply
                                  • evroomE
                                    evroom
                                    Hi @kvicksson ,
                                    To me it seems there are 3 problems here.
                                    You could have a look what the pm2 log says:
                                    You will either have:
                                    or:
                                    or something completely different.
                                    The 3 problems and potential solutions:
                                    You’re config.js entries:
                                    updateInterval: '3600000',
                                    hideBorder: 'true'
                                    should be:
                                    updateInterval: 3600000,
                                    hideBorder: true
                                    even if the module could potentially handle it.
                                    If your mmm-weatherchart instal has this file present:
                                    /home/pi/MagicMirror/modules/mmm-weatherchart/package.json
                                    then you should run:
                                    $ cd /home/pi/MagicMirror/modules/mmm-weatherchart/
                                    $ npm install
                                    If your mmm-weatherchart instal has this file NOT present:
                                    then you should NOT run npm instal, has it will cause havoc to you MagicMirror install.
                                    I would do this in this situation:
                                    $ mv mmm-weatherchart mmm-weatherchart.saved
                                    $ npm install
                                    $ pm2 restart pm2
                                    When it works:
                                    $ rm -rf mmm-weatherchart.saved
                                    Good luck !!
                                    PS @sdetweil : please comment if I am wrong or made mistakes somewhere & thanks for your input.
                                    S K 2 Replies Last reply
                                      sdetweil @kvicksson
                                      @kvicksson said in Blank mm after update:
                                      this is all volunteer… you could post an issue to the module owners github repo… maybe he or someone else will respond… I am like you, just another user…
                                      • evroomE
                                        evroom @kvicksson
                                        I should type faster :-)
                                          sdetweil @evroom
                                          @evroom think u have good instructions…
                                          ps, 2 of my three systems do not have pi as the user, so the path is wrong, and in the module defaults too
                                          • evroomE
                                            evroom
                                            Yes, I assumed user pi and the install under the user pi home directory.
                                            Will try to remember that in the future.
                                            Tilde for the home directory should work on all platforms, is my understanding.
                                            ~/MagicMirror
                                            My keyboard is lacking a tilde and I always forget the right keystrokes.
                                            So /home/pi is faster. :-)
