    Blank mm after update
    48 Posts 4 Posters 20.0k Views 4 Watching
    • K Offline
      kvicksson
      After updated to 2.8.0 I have trouble with a blank screen. I comment out every module one at a time and found out that mmm-weatherchart was the problem. Is there something wrong in my code?
      		module: 'mmm-weatherchart',
      		position: 'bottom_left',
      			country: 'Sweden',
      			area: 'Halland',
      			city: 'Stråvalla',
      			updateInterval: '3600000',
      			hideBorder: 'true'
      • evroomE Offline
        evroom
        @kvicksson said in Blank mm after update:
        It should be Holland :-)
        No, just joking, try:
        			country: 'Sweden',
        			area: 'Halland',
        			city: 'Stråvalla',
        			updateInterval: 3600000,
        			hideBorder: true
        And this should be part of your tool-set:
        cd ~/MagicMirror; npm run config:check
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
        • lavolp3L Offline
          lavolp3 Module Developer @evroom
          @evroom well with the config:check he would not have found the error, would he? It’s a pure semantic check, not a logic one.
          Isn’t there some Troubleshooting guide around to reference to everytime these questions come up?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • K Offline
            kvicksson
            Just to be clear, I’m a girl… ;)
            The module worked as a charm before the update. So you think I should just skip the apostrophe on the updateInterval and hideBorder?
              sdetweil @kvicksson
              @kvicksson ok… before the update it worked…
              does the module contain a package.json file?
              if so you must also run npm install in the module folder as the version of electron changed in 2.8.0
              in the future, i hope my update script will help solve these problems…
              see
              https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                sdetweil @kvicksson
                @kvicksson the rules are text needs quotes (’ or " matching)
                numbers and true/false should NOT have quotes… as they become strings and not numeric or logical values
                if variable == true will fail with quoted values…
                • evroomE Offline
                  evroom @lavolp3
                  @lavolp3 said in Blank mm after update:
                  In this case perhaps not, but it cannot hurt to run it in order to exclude error(s) before and after this part of the config.
                  Normally a 'true' versus true would not cause a black screen, but I might be wrong.
                  And a trouble shooting guide would have to start with the config:checkIMHO.
                  Test environment:
                    sdetweil @evroom
                    @evroom said in Blank mm after update:
                    Normally a ‘true’ versus true would not cause a black screen
                    u don’t know how the module code might fail…
                    which is what causes the blackscreen to begin with
                    • evroomE Offline
                      evroom
                      @sdetweil said in Blank mm after update:
                      Tried the module myself.
                      https://github.com/paphko/mmm-weatherchart
                      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 100
                      0|mm       | Starting MagicMirror ...
                      0|mm       |
                      0|mm       | > magicmirror@2.8.0 start /home/pi/MagicMirror
                      0|mm       | > sh run-start.sh
                      0|mm       |
                      0|mm       | Starting MagicMirror: v2.8.0
                      0|mm       | Loading config ...
                      0|mm       | Loading module helpers ...
                      0|mm       | No helper found for module: alert.
                      0|mm       | Initializing new module helper ...
                      0|mm       | Module helper loaded: updatenotification
                      0|mm       | Whoops! There was an uncaught exception...
                      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      0|mm  | Launching application.
                      Indeed a black screen.
                      Now how to help the girl from Stråvalla ?
                      Test environment:
                        sdetweil @evroom
                        0|mm | Initializing new module helper …
                        0|mm | Loading module helpers …
                        0|mm | Whoops! There was an uncaught exception…
                        seems odd that there would be two invocations of these modules…
                        but as a test, in MagicMirror/config/config.js add
                            disabled: true,
                        to both those modules, and restart mm and see what happens
                        • 1 / 5
