    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 288.8k Views 35 Watching
    • H
      hattlegr @ianperrin
      @ianperrin Here is the log after installing --production.
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', '--production' ]
      2 info using npm@5.6.0
      3 info using node@v9.11.2
      4 verbose npm-session 72bb8575f86ed6c8
      5 silly install runPreinstallTopLevelLifecycles
      6 silly preinstall MMM-Strava@2.0.0-BETA
      7 info lifecycle MMM-Strava@2.0.0-BETA~preinstall: MMM-Strava@2.0.0-BETA
      8 silly install loadCurrentTree
      9 silly install readLocalPackageData
      10 silly install loadIdealTree
      11 silly install cloneCurrentTreeToIdealTree
      12 silly install loadShrinkwrap
      13 silly saveTree MMM-Strava@2.0.0-BETA
      14 verbose stack SyntaxError: Unexpected token < in JSON at position 9216
      14 verbose stack     at JSON.parse (<anonymous>)
      14 verbose stack     at module.exports (/usr/lib/node_modules/npm/lib/utils/parse-json.js:3:15)
      14 verbose stack     at BB.join (/usr/lib/node_modules/npm/lib/install/read-shrinkwrap.js:31:20)
      14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      14 verbose stack     at Holder$3._callFunction (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:14:44)
      14 verbose stack     at Holder$3.checkFulfillment (eval at generateHolderClass (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:92:16), <anonymous>:29:30)
      14 verbose stack     at Promise.eval (eval at thenCallback (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/join.js:14:16), <anonymous>:6:20)
      14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:566:21)
      14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
      14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:693:18)
      14 verbose stack     at Promise._fulfill (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:638:18)
      14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:582:21)
      14 verbose stack     at /usr/lib/node_modules/npm/node_modules/bluebird/js/release/nodeback.js:42:21
      15 verbose cwd /home/pi/MagicMirror/modules/mmm-strava
      16 verbose Linux 4.9.80-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--production"
      18 verbose node v9.11.2
      19 verbose npm  v5.6.0
      20 error Unexpected token < in JSON at position 9216
      21 verbose exit [ 1, true ]
      • H
        hattlegr @hattlegr
        @hattlegr Note the error on line 20 related to a token which could be a possible reason MM does not remember the authorization.
        • I
          ianperrin @hattlegr
          @hattlegr it sounds like you’ve got at least a couple of issues here. One relating to the install of the module and another related to the authorisation process. Let’s take them one at a time.
          What command are you running to install the module and which directory are you in at the time?
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          • H
            hattlegr @ianperrin
            @ianperrin I went right back to the beginning and started the installation again to ensure I save each step.
            During the process I picked up on an error I did not follow up on. After installing --production I had to run ‘npm audit fix’
            After running this I tried the authentication again. This time the process did add the token.js file to the MMM=Strava module.
            I believe it is working now. I have logged off and rebooted to confirm and the Strava module was working correctly.
            pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ git checkout develop && git pull
            Branch develop set up to track remote branch develop from origin.
            Switched to a new branch 'develop'
            Already up-to-date.
            pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ npm install --production
            npm WARN conflict A git conflict was detected in package-lock.json. Attempting to auto-resolve.
            npm WARN conflict To make this happen automatically on git rebase/merge, consider using the npm-merge-driver:
            npm WARN conflict $ npx npm-merge-driver install -g
            npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
            added 55 packages from 67 contributors and audited 3075 packages in 32.396s
            found 1 moderate severity vulnerability
              run `npm audit fix` to fix them, or `npm audit` for details // Was important to run this command to make authentication process work correctly
            pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ npm audit fix
            added 537 packages from 583 contributors in 92.726s
            fixed 1 of 1 vulnerability in 3075 scanned packages
                                   === npm audit security report ===
            found 0 vulnerabilities
            // Config
            			module: "MMM-Strava",
            			position:  "center",
            				client_id: "3---6",
            				client_secret: "f22b--------------------0d9f7",
            				mode: "chart",
            				auto_rotate: "true",
            				units: "imperial"
            • lavolp3L
              lavolp3 Module Developer @ianperrin
              @ianperrin said in MMM-Strava:
              @zerodegree79 , @Val07300, @ctatos (and others I may have missed).
              A new (beta) version of the module with support for Strava’s new authentication flow is available.
              Just wanted to report that the module is working fine until now using the development branch.
              What I would like to implement is some kind of a record panel showing the fastest 1k, 5k, 10k for running 20k, 40k, for cycling etc.
              I can’t see this in the API. Does anyone know a way to extract these values?
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • L
                Lorenz
                When i use the new development branch the api for profile switcher isn’t working anymore. (the notification from MMM-Remote to be exact)
                • lavolp3L
                  Hi all, Hi @ianperrin
                  I love hunting for segments and for that I would like to include some kind of “crown board” calculating golden, silver and bronze crowns for first, second and third places in segments.
                  At a later stage I can imagine including more information, e.g. some kind of notification if you lose a first pace to someone else.
                  However, it’s not easy to get these numbers via the API.
                  So, to summarise: I need the count of podium places for segments in running and cycling. These can change over time! So need to be checked and counted regularly.
                  For these I need all segments the athlete has competed in.
                  My approach would be:
                  Go through ALL activities, pick segment ID’s, combine these and search through each segment leaderboard for the athlete’s name.
                  However, this would be a LOT of API calls. And these are limited to 600 in 15 min. With a few hundred activities these can be exceed easily.
                  So the call would somehow need to be stretched and used not with every other call.
                  Any other ideas or input for this idea?
                  Thanks for every input, as always!
                  • lavolp3L
                    Hi all, hi @ianperrin ,it’s me again.
                    I’m coding a lot with this module trying to build a bigger version of it, and stumbled upon some odd thing. I have included some console logs and found that for some reason the socket notification “SET_CONFIG” is received twice when the module starts, leading to two api calls directly after another. I can only see one send in the browser console from MMM-Strava.js, but two notification receives in the npm logs. Can someone duplicate our even explain this odd behavior?
                    Thanks!
                      dnovacik
                      Don’t forget that Strava is switching to using refresh tokens from 15th October 2019 and won’t be supporting forever tokens anymore. I started writing a little Strava api library in js, currently with only 2 endpoints and going to add up more ofc.
                      https://github.com/dnovacik/strava-minimal-api
                      • lavolp3L
                        lavolp3 Module Developer @dnovacik
                        @dnovacik Well this module uses the strava-v3 nodejs library by unboundev.
                        github link.
                        I guess that is where the new token procedure should be implemented isn’t it?
                        Care to take a look?
                        • I
                          ianperrin @lavolp3
                          @dnovacik
                          The develop branch for the module contains the changes to support the new authentication approach - I’ll merge that back into the master branch in the coming weeks so the module can continue to be used
                          @lavolp3
                          I extended the Strava-v3 package (see https://github.com/ianperrin/MMM-Strava/blob/develop/strava_api.js) to support the new authentication methods. I guess these could be incorporated into a pull request for the core package now that it is active again ;)
                            dnovacik
                            @ianperrin gj then, can’t wait to try out the module!
                            • Z
                              zolabus
                              I can’t use the module anymore
                              If I try to reauthorize i have this error
                              {“message”:“Bad Request”,“errors”:[{“resource”:“Authorize”,“field”:“scope”,“code”:“invalid”}]}
                              Any help please?
                              • I
                                ianperrin @zolabus
                                @zolabus said in MMM-Strava:
                                Any help please?
                                @zolabus - I’ve just released version 2.0.0 of the plugin which is available via the Master branch. Can you try this version?
                                When updating please make sure you run npm install --production from the MMM-Strava directory.
                                If you continue to get these errors, please check the Authorization Callback Domain in your Strava API Settings (https://www.strava.com/settings/api) matches the IP address/URL used to access MagicMirror
                                Z 1 Reply Last reply Reply Quote 0
                                • Z
                                  zolabus @ianperrin
                                  @ianperrin
                                  Hi I updated the module
                                  When I restart the Magic Mirror I receive this
                                  MMM-Strava: “Received notification: SET_CONFIG”
                                  MMM-Strava: “Legacy config in use for module_14_MMM-Strava”
                                  MMM-Strava: “Getting data for module_14_MMM-Strava”
                                  MMM-Strava: “Access token not found for module_14_MMM-Strava”
                                  • Z
                                    zolabus @zolabus
                                    @ianperrin
                                    Issue resolved thanks
                                      MisterT
                                      Hi everybody,
                                      I posted in troubleshooting section but i don’t know if it’s visible. That’s why i post here. I don’t understand the step 2 and the step 5 in Tutorial about MMM-Strava. I have a ID and a secret but i don’t know what i write in case:
                                      APi Name
                                      Category
                                      Club
                                      WebSite
                                      Description
                                      and Callback domain
                                      In Website and Callback domain what i write?
                                      In callback domain, i put my IP to my magic mirror like 192.128.1.99:8080 but nothing happen
                                      Can anybody help me please?
                                      • I
                                        ianperrin @MisterT
                                        @MisterT
                                        When creating your Strava API Application in Step 2, the key value is the Authorisation Callback Domain. This needs to the IP address or domain name you use to access the MagicMirror otherwise subsequent steps will fail. So in your case it looks like you should use 192.128.1.99
                                        Once the API Application is created, add the module to your config.js file with the client_id and client_secret then restart the mirror.
                                        The module should then state Client id unauthorised and provide a link to the authorisation process. At which point you should be able to follow step 5
                                        Here’s two screenshots which might help:
                                        Strava API Settings
                                        Strava API id and secret
                                          MisterT
                                          ok thanks ianperrin for your help
                                          Step 2 is ok because on magic mirror, i have the link on magic mirror : client unauthorized see /MMM-Strava/auth/
                                          but now in step 5, i make:
                                          in webpage, and magic mirror starting i put
                                          http://192.128.1.99:8080/MMM-Strava/Oauth/
                                          but nothing happen. The webpage says:
                                          host unreachable
                                          ERR_CONNECTION_REFUSED
                                          have you an idea?
                                          • I
                                            ianperrin @MisterT
                                            @MisterT is it possible you’re typing in the wrong url. Try using
                                            http://192.128.1.99:8080/MMM-Strava/auth/ or simply clicking the link displayed by the module on the mirror.
                                            If that fails, are you able to access your mirror via http://192.128.1.99:8080/ ?
                                            Finally, can you make sure you ran npm install --production in step 1 and restarted the mirror?
                                            • 4 / 7
