    USB IR touch screen frames on a Pi 4
    8 Posts 4 Posters 1.5k Views 4 Watching
      Rahmberg
      Does anyone have experience using USB IR touch screen frames on a Pi 4?
      I’ve attached the one I’m looking at as a link.
      http://keetouch.eu/en/touchscreen/wkmi-0400
        [[global:former-user]] @Rahmberg
        @Rahmberg Is it working under the spyglass? Or you put it on the spyglass?
          cyberphox
          I have one working on a Pi 3b+
            Rahmberg @Guest
            @Sean The frame will sit on top of the mirror which will be a 30/70 dielectric mirror is not a spyglass.
            I’m pretty sure that part will work, where my concerns are is software.
            Is it possible to control the mirror and make inputs with this product?
              Rahmberg @cyberphox
              @cyberphox Great then there should be no problem using it on a Pi 4.
              What obstacles and restrictions have you experienced?
              Can it use multiple touches or just single touches?
                cyberphox
                Right now my biggest issue is that I have to run a command to rotate the touch frame…and once the monitor goes to sleep and comes back on, those settings are lost. So I may have to just use it in landscape mode
                • cowboysdudeC Offline
                  Since it doesn’t need a ‘driver’ to work it’s just plug and play … it’ll work.
                    Rahmberg
                    thanks for all your feed back
