    USB IR touch screen frames on a Pi 4
    8 Posts 4 Posters 1.3k Views 4 Watching
      A Former User @Rahmberg
      @Rahmberg Is it working under the spyglass? Or you put it on the spyglass?
        cyberphox
        I have one working on a Pi 3b+
          Rahmberg @Guest
          @Sean The frame will sit on top of the mirror which will be a 30/70 dielectric mirror is not a spyglass.
          I’m pretty sure that part will work, where my concerns are is software.
          Is it possible to control the mirror and make inputs with this product?
            Rahmberg @cyberphox
            @cyberphox Great then there should be no problem using it on a Pi 4.
            What obstacles and restrictions have you experienced?
            Can it use multiple touches or just single touches?
              cyberphox
              Right now my biggest issue is that I have to run a command to rotate the touch frame…and once the monitor goes to sleep and comes back on, those settings are lost. So I may have to just use it in landscape mode
              • cowboysdudeC Offline
                Since it doesn’t need a ‘driver’ to work it’s just plug and play … it’ll work.
                  Rahmberg
                  thanks for all your feed back
