    Default Modules
    Scheduled Pinned Locked Moved Modules
    11 Posts 9 Posters 23.4k Views 8 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      The following modules come with a default installation of MagicMirror²:
      Alert            - Displays alerts on the mirror when configured in another module.
      Clock            - Display either a digital, analog, or both types of clocks
      Calendar         - Displays a calendar of upcoming events, able to use Google and Facebook calendars.
      Current Weather  - Displays the current weather for the configured location
      Weather Forecast - Displays the weather forecast for the configured location
      News Feed        - Displays a running ticker of a news feed, able to use a variety of different feeds
      Compliments      - "Hi Sexy!"
      Hello World      - Sample module, not enabled by default
      Third party modules change almost daily. It’s the author’s own responsibility to post their module in the Showcase category.
      • N Offline
        nem1
        Just a quick question to the Weather Forecast default module. It is working fine, thanks for that, but:
        Today, we have Monday and the weather for today is shown by using the module current weather. Why is the monday (today) also included in the weather forecast?
        Thank you!
          doubleT Module Developer
          For the sake of completeness I’d say that even on the current day it’s still helpfull to see the forecast with the lowest and highest temp throughout the day.
          The reason I revided this thread, though, is: DECIMAL MARKS IN WEATHER MODULES
          I saw a lot of Mirrors from German users with typographically wrong decimal marks in the defeault modules Current Weather and Weather Forecast (9.5°C vs 9,5°C).
          With the latest update, there’s the possibility to change the decimal mark from the English decimal dot to the German (and other language’s) decimal comma. If you’re not sure what decimal mark your language is using, check this list on Wikipedia.
          Usage:
          In the config of currentweather and weatherforecast, just add the line
          decimalSymbol: ","
          only with MagicMirror² v2.2.0 and up
          • T Offline
            thereallegend27
            @KirAsh4 just adding a link to github for the default modules as was difficult to find the second time I was looking for it.
            https://github.com/MichMich/MagicMirror/tree/master/modules/default
            • N Offline
              n21brown @nem1
              @nem1 I’ve got the same problem with the forecast too. After approx 15:00 in a day I dont want to see that day’s for cast as it’s 60% of the day gone, therefore the next day should be shown.
                sdetweil @n21brown
                @n21brown open an issue on the magicmirror github site so someone can track it.
                if you are a programmer, and want to contribute the fix as u care about it, then fork the repo, and make changes, then submit a pull request back. we are all volunteers on this project
                and if u are not a programmer, maybe its a new challenge?
                • bjjsoulB Offline
                  bjjsoul
                  who knows what the module ; Hello World does
                  is this a voice command or news
                  i want to know what is the function of ; Hello World
                  how i can activate it
                  • brobergB Offline
                    broberg Project Sponsor @bjjsoul
                    @bjjsoul it does nothing but display the text “hello world”. It’s a super basic template for buildinh your own module.
                      david_jonesy @KirAsh4
                      @KirAsh4 looks like latest calendar build has an issue with “broadcastPastEvents”
                      If I set it to true, it will not display any events. Calendar only works if set to false.
                      • O Offline
                        Oboudreaux
                        A little improvement on compliments: a day of the week category.
                        const day = moment().format("dddd");
                        if (day in this.config.compliments) {
                                      compliments.push.apply(compliments, this.config.compliments[day])
                        allows entries like:
                        "Monday" : [
                            "Looks like somebody has a case of the Mondays"
                        "Tuesday" : [
                            "Take out the trash."
                        Sorry, I didn’t see a better place to drop this
                          sdetweil @Oboudreaux
                          @Oboudreaux submit a PR to the GitHub repo
