    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 137.7k Views 38 Watching
      Chris62 @AgP42
      @AgP42
      Hi
      I don’t actually have a password set for the camera, it has been factory reset to the defaults which just gives a username admin and a blank password field. My url looks like this http://admin:@ipaddress:port/video/mjpg.cgi. Maybe this is the cause of the issue?
      Chris.
        smassy
        @AgP42
        Hello again, I’m trying to use the embeded calls “SWD_…” but there is something I’m not getting.
        var recipe = {
          transcriptionHook: {
            "playlist_sylvain": {
              pattern: "liste sylvain",
              command: "playlist_1"
            "playlist_lewis": {
              pattern: "liste lewis capaldi",
              command: "playlist_2"
            "playlist_pause": {
              pattern: "arrêt lecture",
              command: "playlist_pause"
            "playlist_play": {
              pattern: "démarre lecture",
              command: "playlist_play"
          command: {
             "playlist_1": {
                     notificationExec: {
                             notification: "SWD_URL",
                             payload: {
                                     url:["https://www.youtube.com/embed/0-rG98j2DWE?list=PLa51J4RKCoTXCfr-qubj2FUgPADypF3Gk&autoplay=1"],
             "playlist_2": {
                     notificationExec: {
                            payload: {
                                    url:["https://www.youtube.com/embed/bCuhuePlP8o?list=RDEMsPjiovzEgfLLK2w1FvFTOg&autoplay=1"],
             "playlist_pause": {
                     notificationExec: {
                            notification: "SWD_PAUSE",
             "playlist_play": {
                     notificationExec: {
                            notification: "SWD_PLAY",
        exports.recipe = recipe
        Lists are starting correctly but when calling SWD_PAUSE it’s doing nothing and SWD_PLAY restart the list at beginning. Any clue?
        A 1 Reply Last reply
        • A
          AgP42 Project Sponsor Module Developer @smassy
          @smassy said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
          @AgP42
          yes, it is (unfortunately) the normal behavior, as written on the documentation :
          - Play(or restart)/Pause/Stop the update and rotation of URLs
          In fact I cannot stop the video itself, as it would imply to be connected to YouTube API. Here we “just” display the video. The function “play/pause” are for the rotation of the videos or playlist. If you want to stop the video, the best way will be to have an empty playlist that you can start to stop everything else.
          I know it is bad looking and not intuitive, but I cannot do better with the technical solution with iFrames…
          Sorry !
          • N
            Newtothis @AgP42
            @AgP42
            Hi!
            Love the module, very well done!
            I am using MMM-TelegramBot to control my Mirror, did you ever look into seeing if you could intergrate your module with Telegram?
            A 2 Replies Last reply
            • A
              AgP42 Project Sponsor Module Developer @Newtothis
              @Newtothis said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
              @AgP42
              Hi!
              yes I remember that I had a look on it some months ago and by that time I thought it will not be very complicated to do…
              I don’t really have much time thoses weeks (even months…), but yes someday I may develop that interface ;-)
              N 1 Reply Last reply
              • N
                Newtothis @AgP42
                @AgP42 No worries! Thanks for the reply :)
                • U
                  ueffchen
                  Hi
                  the module loads initially after updating config.js or rebooting the MM, but it doesn’t refresh the iframe.
                  Is there anything in the settings that I should do different?
                  Thanks, ueffchen
                  		module: 'MMM-SmartWebDisplay',
                  		position: 'top_right',	// This can be any of the regions.
                  			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                  			height:"330px", //hauteur du cadre en pixel ou %
                  			width:"330px", //largeur
                                 		updateInterval: 30, //in min. Set it to 0 for no refresh (for videos)
                                  	NextURLInterval: 30, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                  	displayStateInfos: false,	//to display if the module is on autoloop, or stop.
                                  	displayLastUpdate: false, //to display the last update of the URL
                  			displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                                  	url: ["https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.29724&lng=6.84929&overname=2&zoom=11&naam=ratingen&size=2b&voor=1"],
                  			scrolling: "no" // allow scrolling or not. html 4 only
                  A A 2 Replies Last reply
                  • A
                    Alain @ueffchen
                    @ueffchen I have the exact same problem. However, for some reason, when I turn the “displayLastUpdate:” to “true”, it begins updating at the interval set in “updateInterval”. Turn it back to “false”, and it stops updating.
                    Not ideal, since it displays a line of information I don’t want to see; but it does refresh.
                    If someone could help, I would appreciate it too!
                    Thank you
                    Alain
                    • A
                      AgP42 Project Sponsor Module Developer @ueffchen
                      @ueffchen said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                      Hi
                      Thanks, ueffchen
                      Hi @ueffchen,
                      when I test the url on iFrame tester (here : iFrame), I don’t need any refresh, the radar is live display without any refresh.
                      Isn’t it the same on the mirror ?
                      Otherwise on the config, as you have only 1 URL, this param "NextURLInterval: 30, " has to be set to 0 (but it cannot be the reason of non-refresh…)
                      And as you set the "updateInterval: 30, ", then here you request a refresh every 30 MINUTES, was it the refresh you wanted ?
                      Bye,
                      AgP
                      • A
                        AgP42 Project Sponsor Module Developer @Alain
                        @Alain said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                        Thank you
                        Alain
                        Hello @Alain ,
                        yes strange behavior indeed !
                        Could you please share your full config to check what could be wrong ?
                        Thanks,
                        AgP
                          Phil__
                            brotherbrown831
                            I have seen a few examples of people displaying Action-tiles URLs in the MM. The action-tiles team does not allow username and passwords to be passed in the URL, the user must login to Action-tiles and then can navigate directly to the URL. Is there a solution to this requirement within SmartWebDisplay?
                            A B 2 Replies Last reply
                            • A
                              AgP42 Project Sponsor Module Developer @brotherbrown831
                              @brotherbrown831
                              sorry but I don’t understand what you want to do, do you want to use a URL with a name and password on it ?
                              Or do you want to use a pop up to log in and then access a URL ?
                              You say “the action-tiles team”, what it this ? Do you have any documentation ?
                              Thanks for a bit more detail ;-)
                              • A
                                @Newtothis @rafaelcota
                                You asked the compatibility with the module MMM-TelegramBot, and I finally took the time today to integrate it.
                                It is in “beta” so far, I must now write the documentation (really less fun that writing code :smiling_face_with_halo: )
                                The code is here : https://github.com/AgP42/MMM-SmartWebDisplay/tree/beta, if you could test and let me know your feedback it will be very appreciated !!
                                The commands are (still time to change them if you don’t like thoses ones…) :
                                /swd_next
                                /swd_prev
                                /swd_play
                                /swd_pause
                                /swd_stop
                                /swd_url (then the url you want to display on your MagicMirror)
                                for example “/swd_url http://magicmirror.builders/”
                                for the URL I didn’t give the possibility to send a list, but could be improved.
                                Thanks for your feedback !
                                • A
                                  I finalize the version, it is now available for everyone !
                                  To update (as every module) :
                                  cd ~/MagicMirror/modules/MMM-SmartWebDisplay
                                  git pull
                                  Enjoy ;-)
                                  • A
                                    Alain @AgP42
                                    @AgP42 Hi - sorry for not replying sooner.
                                    Full config file as follows:
                                    /* Magic Mirror Config Sample
                                     * MIT Licensed.
                                    var config = {
                                    address: "0.0.0.0", // Address to listen on, can be:
                                    port: 8080,
                                    ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.0.43", "192.168.0.46"], // Set [] to allow all IP addresses
                                    language: "en",
                                    timeFormat: 24,
                                    units: "metric",
                                    module: "alert",
                                    module: "updatenotification",
                                    position: "top_bar"
                                    module: "clock",
                                    position: "top_left"
                                    header: "US Holidays",
                                    position: "bottom_right",
                                    symbol: "calendar-check",
                                    url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" }
                                    module: "compliments",
                                    position: "middle_center"
                                    module: "currentweather",
                                    locationID: "4172173",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    appid: "xxx"
                                    module: "weatherforecast",
                                    position: "bottom_left",
                                    header: "Weather Forecast",
                                    appid: "xxx"
                                    module: "newsfeed",
                                    position: "bottom_bar",
                                    feeds: [
                                    title: "New York Times",
                                    showSourceTitle: true,
                                    showPublishDate: true,
                                    broadcastNewsFeeds: true,
                                    broadcastNewsUpdates: true
                                          module: "MMM-Remote-Control",
                                    // position: "top_right",
                                                apiKey: "xxx"
                                    module: "MMM-SmartWebDisplay",
                                    position: "top_right", // This can be any of the regions.
                                    logDebug: true, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                                    height:"300px", //hauteur du cadre en pixel ou %
                                    width:"525px", //largeur
                                                    updateInterval: 1, //in min. Set it to 0 for no refresh (for videos)
                                                    NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                                    displayLastUpdate: true, //to display the last update of the URL
                                    displayLastUpdateFormat: 'HH:mm:ss', //format of the date and time to display
                                                    url: ["https://xxx/public/magic1.html"], //source of the URL to be displayed
                                    module: "MMM-PIR-Sensor",
                                    sensorPin: 22,
                                    powerSavingNotification: false,
                                    powerSavingDelay: 100
                                            module: "MMM-Astronauts",
                                            position: "bottom_center",
                                    useHeader: false,                // true if you want a header
                                    header: "",                      // Change in config file. useHeader must be true
                                    maxWidth: "300px",
                                    animationSpeed: 3000,            // fade speed
                                    A S 2 Replies Last reply
                                    • A
                                      Hi @Alain,
                                      first please remove all your apikey on your post before :winking_face:
                                      I see that you also use the MMM-PIR-sensor module, with a delay of 100s, this is probably the root cause of the strange behavior that you saw.
                                      Let me explains you my analysis :
                                      Here is how this sensor work (Source) :
                                      PIR
                                      The delay of detection or non-detection as to be set directly on the sensor !
                                      So your sensor will sent to the module “MMM-PIR-Sensor” 2 possible states “HIGH” (presence) or “LOW” (no presence).
                                      Each time the MMM-PIR-Sensor will receive a modification of the sensor status, it will sent immediately (to everyone, so to MMM-SmartWebDisplay too) a notification saying “USER_PRESENCE=true” or false.
                                      Developer Notes (MMM-PIR-Sensor)
                                      This module broadcasts a USER_PRESENCE notification with the payload beeing true or false you can use it to pause or disable your module.
                                      The “powerSavingDelay” is applied after this notification is sent to everyone.
                                      And my module “MMM-SmartWebDisplay” use this notification to stop and restart the update timer.
                                      So by setting 100s of delay on the MMM-PIR-Sensor module, it probably totally mix up all the update timer management of my module. :loudly_crying_face:
                                      A small example :
                                      • Nobody in front of the mirror for long time, so Mirror is off
                                      • you arrives close to the Mirror, that activate the PIR sensor, the Mirror wakes up and MMM-SmartWebDisplay also wakes up, update the html page to display and set a new refresh in 1 min (because you configure it with 1min)
                                      • your sensor doesn’t detects you anymore : during 100s, so 1min40s your Mirror will stay ON without any notification (because you desactivate “powerSavingNotification”), but MMM-SmartWebDisplay (and all other modules) received the notification “USER_PRESENCE=false”, so MMM-SmartWebDisplay stops the update of the html page.
                                      • if your sensor detects you again during this 100s, then you should see the update of the html (directly when the sensor will send the info to the Mirror) --> Do you confirm this ?
                                      So for me your problem is on the adjustment of your PIR sensor and the value you set for this module configuration. You can follow this very good page to adjust correctly your sensor : PIR sensor
                                      Personally I adjust the detection delay on the sensor itself and I just set 10s of “powerSavingDelay” after a notification (powerSavingNotification: true).
                                      I hope my explaination was clear enough !
                                      Good luck and let me know if you still face issues,
                                      Bye
                                      AgP42
                                      SergeS 1 Reply Last reply
                                      Reply Quote 2
                                        BD0G @brotherbrown831
                                        @brotherbrown831
                                        Sure. What one does is create an actiontiles panel that they want displayed. Then copy the URL that points directly at the panel. This URL must use the http:// prefix in the address and cannot start with just panel.actiontiles.com/
                                        Then turn the refresh setting within the config.js settings to 0
                                        (for no refresh)
                                        The first time that MMM-SmartWebDisplay loads the page/actiontiles panel one will be prompted to log on. Use your credentials to log on. They will be saved by the browser that is running your MagicMirror instance.
                                        Then in the future MMM-SmartWebDisplay will just display the panel itself without the need to log on each time. So there is no need to pass the username and password “within” the URL address. There is a caveat. If you panel contains camera feeds (live Video or Still Image) your camera tile within the panel “may” need logon details like username and password to display. These will not work as username and password cannot be “passed” within the
                                        URL string and be processed.
                                        Just create a panel without the camera streams to be displayed.
                                        • T
                                          ttarzan
                                          Hello everyone, I have 2 instances of the module MMM-SmartWebDisplay running. This works well.
                                          I also use MMM-Pages to rotate contents of the screen. I would also like to rotate one instance of the module MMM-SmartWebDisplay against one with another module. But how do I address it if I have 2 instances? Both instances have the same module name and are only different in size, position and content.
                                            chassain 0
                                            hello,
                                            Rename the folder MMM-SmartWebDisplay2…then the MMM-SmartWebDisplay2.js and inside Module.register(“MMM-SmartWebDisplay2” like this
                                            and call MMM-SmartWebDisplay on page 1 and MMM-SmartWebDisplay2 on page 2
                                            T 1 Reply Last reply
                                            • 3 / 5
