Unsolved 3rd Party Modules with APIs not loading.
Please start MM using
npm start dev
. You should see an error for MMM-Launch.Question: You are cloning the module into the MagicMirror/modules folder? Not into the
default
folder? -
The error, in the dev console on loading, should look like this
Uncaught (in promise) TypeError: Cannot read property 'name' of undefined
. As the api is slow to respond. Then, upon refresh, the module works normally, or should. -
MMM-Launch is located at home/pi/MagicMirror/modules.
The only errors were for openweathermap, so I removed that from the config.
I’m only seeing some warnings, but no more errors.
I’ll include a screenshot here in a minute, but I’m noticing that “MMM-Launch received a module notification: CLOCK_SECOND from sender: clock” is being logged. Is that expected?
EDIT: Screenshot.
I believe that is just the clock module broadcasting a notification and should have no affect on MMM-Launch as MMM-Launch has no action to perform when receiving.
Can you open a browser and try this url?
This post is deleted! -
Going out for a smoke. I’ll be back in 10.
That URL worked great on the browser.
I really appreciate the help troubleshooting.
No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using
npm start dev
and see if it reports receiving the data from the api. It should look something like this>Array (60)
