3rd Party Modules with APIs not loading.
Please start MM using
npm start dev. You should see an error for MMM-Launch.Question: You are cloning the module into the MagicMirror/modules folder? Not into the
defaultfolder? -
The error, in the dev console on loading, should look like this
Uncaught (in promise) TypeError: Cannot read property 'name' of undefined. As the api is slow to respond. Then, upon refresh, the module works normally, or should. -
MMM-Launch is located at home/pi/MagicMirror/modules.
The only errors were for openweathermap, so I removed that from the config.
I’m only seeing some warnings, but no more errors.
I’ll include a screenshot here in a minute, but I’m noticing that “MMM-Launch received a module notification: CLOCK_SECOND from sender: clock” is being logged. Is that expected?
EDIT: Screenshot.
I believe that is just the clock module broadcasting a notification and should have no affect on MMM-Launch as MMM-Launch has no action to perform when receiving.
Can you open a browser and try this url?
This post is deleted! -
Going out for a smoke. I’ll be back in 10.
That URL worked great on the browser.
I really appreciate the help troubleshooting.
No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using
npm start devand see if it reports receiving the data from the api. It should look something like this>Array (60) -
No errors a few minutes in.
@bflbarlow said in 3rd Party Modules with APIs not loading.:
Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
Sounds good and no worries.
Thanks for giving it a shot!
You’re welcome. I’m sure it will get worked out when the right people take a look at it.
Peace.
I’ve sent you a private message
edit the ~/MagicMirror/modules/MMM-MyStandings/node_helper.js
replace the getData function with this
getData: function (notification, url) { var self = this; console.log('requesting:' + url); request({ url: url, method: 'GET' }, function (error, response, body) { if (!error && response.statusCode == 200) { var result = JSON.parse(body); console.log("have data from api size="+body.length); self.sendSocketNotification(notification, result); } else { console.log("MMM-MyStandings : Could not load data."+" error="+error+" status="+response.statusCode); } }); },open a terminal window
stop mirror , pm2 stop 0then start manually
npm start devyou should see
... MMM-MyStandings helper started ... Sockets connected & modules started ... Launching application. Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000 [14416:1017/204410.405574:ERROR:CONSOLE(2564)] "The given range isn't in document.", source: chrome-devtools://devtools/bundled/shell.js (2564) Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 requesting:http://site.web.api.espn.com/apis/v2/sports/basketball/nba/standings?level=3&sort=gamesbehind:asc,winpercent:desc have data from api size=126499or something
please advise
@bflbarlow did u see my message above?
I did.
Sorry, I haven’t had the time to pick up troubleshooting.
Will hope to sometime this weekend.
@bflbarlow cool. thanks for the feedback… i just noticed that I hadn’t tagged you…
no rush
