    3rd Party Modules with APIs not loading.
    32 Posts 3 Posters 12.5k Views 3 Watching
      bflbarlow
      MMM-Launch is located at home/pi/MagicMirror/modules.
      The only errors were for openweathermap, so I removed that from the config.
      I’m only seeing some warnings, but no more errors.
      1_1571359413131_2019-10-17-194212_1824x984_scrot.png 0_1571359413130_2019-10-17-194220_1824x984_scrot.png
        bflbarlow
        I’ll include a screenshot here in a minute, but I’m noticing that “MMM-Launch received a module notification: CLOCK_SECOND from sender: clock” is being logged. Is that expected?
        EDIT: Screenshot.
        Mykle1M 3 Replies Last reply Reply Quote 0
          Mykle1 Project Sponsor Module Developer @bflbarlow
          @bflbarlow
          I believe that is just the clock module broadcasting a notification and should have no affect on MMM-Launch as MMM-Launch has no action to perform when receiving.
            @bflbarlow
            Can you open a browser and try this url?
            https://launchlibrary.net/1.2/launch?next=60&mode=verbose
              bflbarlow
                @bflbarlow
                Going out for a smoke. I’ll be back in 10.
                  bflbarlow
                  That URL worked great on the browser.
                  I really appreciate the help troubleshooting.
                    @bflbarlow
                    No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using npm start dev and see if it reports receiving the data from the api. It should look something like this
                    >Array (60)
                      bflbarlow
                      No errors a few minutes in.
                        @bflbarlow said in 3rd Party Modules with APIs not loading.:
                        Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
                        I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
                          bflbarlow @Mykle1
                          Sounds good and no worries.
                          Thanks for giving it a shot!
                            @bflbarlow
                            You’re welcome. I’m sure it will get worked out when the right people take a look at it.
                            Peace.
                              @bflbarlow
                              I’ve sent you a private message
                                edit the ~/MagicMirror/modules/MMM-MyStandings/node_helper.js
                                replace the getData function with this
                                	getData: function (notification, url) {
                                		var self = this;
                                		console.log('requesting:' + url);
                                		request({ url: url, method: 'GET' }, function (error, response, body) {
                                			if (!error && response.statusCode == 200) {
                                				var result = JSON.parse(body);
                                				console.log("have data from api size="+body.length);
                                				self.sendSocketNotification(notification, result);
                                			} else {
                                				console.log("MMM-MyStandings : Could not load data."+" error="+error+" status="+response.statusCode);
                                open a terminal window
                                stop mirror , pm2 stop 0
                                then start manually
                                npm start dev
                                you should see
                                MMM-MyStandings helper started ...
                                Launching application.
                                Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                [14416:1017/204410.405574:ERROR:CONSOLE(2564)] "The given range isn't in document.", source: chrome-devtools://devtools/bundled/shell.js (2564)
                                Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                requesting:http://site.web.api.espn.com/apis/v2/sports/basketball/nba/standings?level=3&sort=gamesbehind:asc,winpercent:desc
                                have data from api size=126499
                                or something
                                please advise
                                  @bflbarlow did u see my message above?
                                    bflbarlow
                                    I did.
                                    Sorry, I haven’t had the time to pick up troubleshooting.
                                    Will hope to sometime this weekend.
                                      sdetweil @bflbarlow
                                      @bflbarlow cool. thanks for the feedback… i just noticed that I hadn’t tagged you…
                                      no rush
