    3rd Party Modules with APIs not loading.
    32 Posts 3 Posters 11.5k Views 3 Watching
      bflbarlow
        Mykle1 Project Sponsor Module Developer @bflbarlow
        @bflbarlow
        Going out for a smoke. I’ll be back in 10.
          bflbarlow
          That URL worked great on the browser.
          I really appreciate the help troubleshooting.
            @bflbarlow
            No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using npm start dev and see if it reports receiving the data from the api. It should look something like this
            >Array (60)
              bflbarlow
              No errors a few minutes in.
                @bflbarlow said in 3rd Party Modules with APIs not loading.:
                Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
                I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
                  bflbarlow @Mykle1
                  Sounds good and no worries.
                  Thanks for giving it a shot!
                    @bflbarlow
                    You’re welcome. I’m sure it will get worked out when the right people take a look at it.
                    Peace.
                      @bflbarlow
                      I’ve sent you a private message
                        edit the ~/MagicMirror/modules/MMM-MyStandings/node_helper.js
                        replace the getData function with this
                        	getData: function (notification, url) {
                        		var self = this;
                        		console.log('requesting:' + url);
                        		request({ url: url, method: 'GET' }, function (error, response, body) {
                        			if (!error && response.statusCode == 200) {
                        				var result = JSON.parse(body);
                        				console.log("have data from api size="+body.length);
                        				self.sendSocketNotification(notification, result);
                        			} else {
                        				console.log("MMM-MyStandings : Could not load data."+" error="+error+" status="+response.statusCode);
                        open a terminal window
                        stop mirror , pm2 stop 0
                        then start manually
                        npm start dev
                        you should see
                        MMM-MyStandings helper started ...
                        Launching application.
                        Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                        [14416:1017/204410.405574:ERROR:CONSOLE(2564)] "The given range isn't in document.", source: chrome-devtools://devtools/bundled/shell.js (2564)
                        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        requesting:http://site.web.api.espn.com/apis/v2/sports/basketball/nba/standings?level=3&sort=gamesbehind:asc,winpercent:desc
                        have data from api size=126499
                        or something
                        please advise
                          @bflbarlow did u see my message above?
                            bflbarlow
                            I did.
                            Sorry, I haven’t had the time to pick up troubleshooting.
                            Will hope to sometime this weekend.
                              sdetweil @bflbarlow
                              @bflbarlow cool. thanks for the feedback… i just noticed that I hadn’t tagged you…
                              no rush
