    3rd Party Modules with APIs not loading.
    32 Posts 3 Posters 12.3k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @bflbarlow
      @bflbarlow
      I believe that is just the clock module broadcasting a notification and should have no affect on MMM-Launch as MMM-Launch has no action to perform when receiving.
        @bflbarlow
        Can you open a browser and try this url?
        https://launchlibrary.net/1.2/launch?next=60&mode=verbose
          bflbarlow
            @bflbarlow
            Going out for a smoke. I’ll be back in 10.
              bflbarlow
              That URL worked great on the browser.
              I really appreciate the help troubleshooting.
                @bflbarlow
                No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using npm start dev and see if it reports receiving the data from the api. It should look something like this
                >Array (60)
                  bflbarlow
                  No errors a few minutes in.
                    @bflbarlow said in 3rd Party Modules with APIs not loading.:
                    Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
                    I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
                      bflbarlow @Mykle1
                      Sounds good and no worries.
                      Thanks for giving it a shot!
                        @bflbarlow
                        You’re welcome. I’m sure it will get worked out when the right people take a look at it.
                        Peace.
                          @bflbarlow
                          I’ve sent you a private message
                            edit the ~/MagicMirror/modules/MMM-MyStandings/node_helper.js
                            replace the getData function with this
                            	getData: function (notification, url) {
                            		var self = this;
                            		console.log('requesting:' + url);
                            		request({ url: url, method: 'GET' }, function (error, response, body) {
                            			if (!error && response.statusCode == 200) {
                            				var result = JSON.parse(body);
                            				console.log("have data from api size="+body.length);
                            				self.sendSocketNotification(notification, result);
                            			} else {
                            				console.log("MMM-MyStandings : Could not load data."+" error="+error+" status="+response.statusCode);
                            open a terminal window
                            stop mirror , pm2 stop 0
                            then start manually
                            npm start dev
                            you should see
                            MMM-MyStandings helper started ...
                            Launching application.
                            Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                            [14416:1017/204410.405574:ERROR:CONSOLE(2564)] "The given range isn't in document.", source: chrome-devtools://devtools/bundled/shell.js (2564)
                            Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                            requesting:http://site.web.api.espn.com/apis/v2/sports/basketball/nba/standings?level=3&sort=gamesbehind:asc,winpercent:desc
                            have data from api size=126499
                            or something
                            please advise
                              @bflbarlow did u see my message above?
                                bflbarlow
                                I did.
                                Sorry, I haven’t had the time to pick up troubleshooting.
                                Will hope to sometime this weekend.
                                  sdetweil @bflbarlow
                                  @bflbarlow cool. thanks for the feedback… i just noticed that I hadn’t tagged you…
                                  no rush
