    3rd Party Modules with APIs not loading.
    32 Posts 3 Posters 12.3k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @bflbarlow
      @bflbarlow said in 3rd Party Modules with APIs not loading.:
      The MMM-Launch config is directly copy/pasted from the module’s README, minus the location to “bottom_right”.
      I just ran this module. There is a delay in loading (< 30 seconds). I believe it to be an api delay issue because the module will run in less than 30 seconds.
      I just took this screenshot.
        And another as it goes through the rotation.
          bflbarlow
          I’m glad yours works.
          Mine still doesn’t.
          If 30 seconds is what I have to wait, then I’m already 120+ times past that (over an hour) with no rotation.
          I’m curious if you have any suggestions on things to try to help narrow this issue down.
            @bflbarlow
            Try disabling the other modules to see if it loads. If not, I would delete the MMM- Launch module folder and clone it again, trying it alone again. If that does not work then something else is amiss. I assure you, the module does work and it should work for you.
              bflbarlow
              I’ll give that a try.
              I’m not concerned with that specific module not working. 3rd Party Modules I’ve installed that do not utilize APIs work perfectly well and the default modules work perfectly well as well.
              It is a trend however, that of the six total 3rd Party Modules that I have tried and tested that do connect to APIs, none of them appear to be receiving data, which is why I am still slightly suspicious about something being wrong in the general Raspberry Pi configuration. But that wouldn’t explain why the default modules work perfectly well despite pulling from the openweathermap API.
                @bflbarlow
                Then my suggestion should confirm or eliminate that suspicion. Good luck and report back here.
                  bflbarlow
                  Removing the modules file, starting from a fresh config.js, cloning back the modules file, and adding the MMM-Launch config didn’t yield any data after the last 5 minutes.
                  I’m thinking I’ll just cut ties and start again from scratch with a fresh install of raspbian. Maybe that’ll reset anything that might have gone haywire in the setup.
                    bflbarlow
                    Unfortunately, a fresh raspbian image and MagicMirror install doesn’t appear to solve the problem.
                    Still open to any/all suggestions.
                    It’s been sitting on T - Minus 5 seconds for the last 10 minutes.
                      @bflbarlow
                      Please start MM using npm start dev. You should see an error for MMM-Launch.
                      Question: You are cloning the module into the MagicMirror/modules folder? Not into the default folder?
                        The error, in the dev console on loading, should look like this
                        Uncaught (in promise) TypeError: Cannot read property 'name' of undefined. As the api is slow to respond. Then, upon refresh, the module works normally, or should.
                          bflbarlow
                          MMM-Launch is located at home/pi/MagicMirror/modules.
                          The only errors were for openweathermap, so I removed that from the config.
                          I’m only seeing some warnings, but no more errors.
                          1_1571359413131_2019-10-17-194212_1824x984_scrot.png 0_1571359413130_2019-10-17-194220_1824x984_scrot.png
                            bflbarlow
                            I’ll include a screenshot here in a minute, but I’m noticing that “MMM-Launch received a module notification: CLOCK_SECOND from sender: clock” is being logged. Is that expected?
                            EDIT: Screenshot.
                            Mykle1M 3 Replies Last reply Reply Quote 0
                              @bflbarlow
                              I believe that is just the clock module broadcasting a notification and should have no affect on MMM-Launch as MMM-Launch has no action to perform when receiving.
                                @bflbarlow
                                Can you open a browser and try this url?
                                https://launchlibrary.net/1.2/launch?next=60&mode=verbose
                                  bflbarlow
                                    @bflbarlow
                                    Going out for a smoke. I’ll be back in 10.
                                      bflbarlow
                                      That URL worked great on the browser.
                                      I really appreciate the help troubleshooting.
                                        @bflbarlow
                                        No problem. Ok, so you can get data. Now let’s see what the module tells us about getting the data. Can you go in the MMM-Launch.js file and uncomment line 124. Save. Run MM again using npm start dev and see if it reports receiving the data from the api. It should look something like this
                                        >Array (60)
                                          bflbarlow
                                          No errors a few minutes in.
                                            Sucks! You should see it right away. I’m stumped. I can’t reproduce this behavior with my module. You CAN get data, based on the url test. But, for you, the module is not getting the data. Thus, it’s not loading.
                                            I don’t think this is a module issue. I’ll ask my friend on the forum to look into this for you. He is amazing at troubleshooting MM and modules. I’m sure he will take a look at this. I’m sorry I couldn’t figure this out for you.
