MMM-Rest
@Tuxdiver you can open the console in electron with
cmd+shift+I
or start the mirror withnpm start dev
, then the console will be open from start -
@Tuxdiver
I add debug mode, but where can i find the log ?I try a tcpdump, and they arre no connection to the url :
pi@mirror:~/MagicMirror/modules/MMM-Rest $ sudo tcpdump |grep dirk
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytesStay in loading mode
Thanks in advance -
@balthaz Sorry for the delay… The problem is the same-origin-policy of JavaScript: you must not call any other server than the one, where the mirror is running.
I will change the module to use a node helper, but that might take some time.
Module is updated on Github. Please try again. Now it uses a node_helper.js to fetch the remote data. Should solve the security “bug” of AJAX…
@Tuxdiver What kind of sensors are you using for this internally (your openHAB)?
I am currently on vacation, I will try on my return.
Thanks -
I have an ESP8266 / NodeMCU sensors in every room, which send temperate and humidity values via MQTT to the mirror running mosquitto MQTT broker and openHAB. The values from the openHAB - API are then displayed on the mirror using my module.
@Tuxdiver Yes it’s working good now :)
Is it possible to display alphanumeric response?Thanks
Hello, i have problem with this module : saying Module Loading. I have installed newest version from github. It is clear instalation with no others module. How can I check where is the problem.
No need copy my config because it’s only one module copied from repository this module.
