MagicMirror won't start with newest build
8 Posts 4 Posters 2.1k Views 3 Watching
    parthp90
    after running npm start, I keep getting the following error:
    > magicmirror@2.9.0 start /home/pi/MagicMirror
    > sh run-start.sh
    /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
    /home/pi/MagicMirror/node_modules/electron/dist/electron: /usr/lib/arm-linux-gnueabihf/libnss3.so: version `NSS_3.22' not found (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the magicmirror@2.9.0 start script.
    npm ERR!     /home/pi/.npm/_logs/2019-10-27T15_55_59_428Z-debug.log
    Not sure where to go from here, any help would be appreciated. Thanks!
    • S Online
      sdetweil @roooooony
      @roooooony
      can you do
      ls /usr/lib/arm-linux-gnueabihf/libnss3.so -laF
      and
      ls /lib/arm-linux-gnueabihf/libdbus-1.so.3 -laF
      mine are dated aug 22 and Jun 9 (libdbus-1.so.3.19.11) respectively
      and a thing to test out
      rename the ~/MagicMirror/node_modules/electron folder to some other name
      then do
      npm install electron@6.0.12
      then try to start MagicMirror
      R 1 Reply Last reply Oct 31, 2019, 4:59 AM Reply Quote 2
        broberg Project Sponsor
        After update, did you run Npm install in the magicmirror folder?
        P 1 Reply Last reply Oct 27, 2019, 7:17 PM Reply Quote 0
          parthp90 @broberg
          @broberg I did, but I still get the same error. I’ve also tried doing multiple fresh installs including using the updated installer script (https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer), but always end up with that same error
          S 1 Reply Last reply Oct 27, 2019, 7:55 PM Reply Quote 0
          • S Online
            sdetweil @parthp90
            @parthp90 looks like u don’t have some graphics libraries. So, search Google on the two libs. And install them.
            What os are your running?
            And in graphics mode? Right?
              roooooony
              I am having the same error, any guidance would be greatly appreciated ( : Thanks!
              S 1 Reply Last reply Oct 31, 2019, 4:21 AM Reply Quote 0
              • S Online
                sdetweil @roooooony
                @roooooony
                can you do
                and
                then do
                  roooooony @sdetweil
                  @sdetweil This worked! Thank you for the quick reply!
                  S 1 Reply Last reply Oct 31, 2019, 11:48 AM Reply Quote 0
                  • S Online
                    sdetweil @roooooony
                    @roooooony thanks… I have opened issue 1800 to document this problem
