    MagicMirror won't start with newest build
    8 Posts 4 Posters 2.4k Views 3 Watching
      parthp90
      after running npm start, I keep getting the following error:
      > magicmirror@2.9.0 start /home/pi/MagicMirror
      > sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
      /home/pi/MagicMirror/node_modules/electron/dist/electron: /usr/lib/arm-linux-gnueabihf/libnss3.so: version `NSS_3.22' not found (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-10-27T15_55_59_428Z-debug.log
      Not sure where to go from here, any help would be appreciated. Thanks!
        sdetweil @roooooony
        @roooooony
        can you do
        ls /usr/lib/arm-linux-gnueabihf/libnss3.so -laF
        and
        ls /lib/arm-linux-gnueabihf/libdbus-1.so.3 -laF
        mine are dated aug 22 and Jun 9 (libdbus-1.so.3.19.11) respectively
        and a thing to test out
        rename the ~/MagicMirror/node_modules/electron folder to some other name
        then do
        npm install electron@6.0.12
        then try to start MagicMirror
        R 1 Reply Last reply Reply Quote 2
        • brobergB Offline
          broberg Project Sponsor
          After update, did you run Npm install in the magicmirror folder?
            parthp90 @broberg
            @broberg I did, but I still get the same error. I’ve also tried doing multiple fresh installs including using the updated installer script (https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer), but always end up with that same error
              sdetweil @parthp90
              @parthp90 looks like u don’t have some graphics libraries. So, search Google on the two libs. And install them.
              What os are your running?
              And in graphics mode? Right?
                roooooony
                I am having the same error, any guidance would be greatly appreciated ( : Thanks!
                  sdetweil @roooooony
                  @roooooony
                  can you do
                  and
                  then do
                    roooooony @sdetweil
                    @sdetweil This worked! Thank you for the quick reply!
                      sdetweil @roooooony
                      @roooooony thanks… I have opened issue 1800 to document this problem
