MagicMirror won't start with newest build
after running npm start, I keep getting the following error:
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.9.0 start /home/pi/MagicMirror > sh run-start.sh /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron) /home/pi/MagicMirror/node_modules/electron/dist/electron: /usr/lib/arm-linux-gnueabihf/libnss3.so: version `NSS_3.22' not found (required by /home/pi/MagicMirror/node_modules/electron/dist/electron) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.9.0 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.9.0 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-10-27T15_55_59_428Z-debug.logNot sure where to go from here, any help would be appreciated. Thanks!
@roooooony
can you dols /usr/lib/arm-linux-gnueabihf/libnss3.so -laF and ls /lib/arm-linux-gnueabihf/libdbus-1.so.3 -laFmine are dated aug 22 and Jun 9 (libdbus-1.so.3.19.11) respectively
and a thing to test out
rename the ~/MagicMirror/node_modules/electron folder to some other name
then docd ~/MagicMirror npm install electron@6.0.12then try to start MagicMirror
After update, did you run Npm install in the magicmirror folder?
@broberg I did, but I still get the same error. I’ve also tried doing multiple fresh installs including using the updated installer script (https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer), but always end up with that same error
@parthp90 looks like u don’t have some graphics libraries. So, search Google on the two libs. And install them.
What os are your running?
And in graphics mode? Right? -
I am having the same error, any guidance would be greatly appreciated ( : Thanks!
@roooooony
@sdetweil This worked! Thank you for the quick reply!
@roooooony thanks… I have opened issue 1800 to document this problem
