    Halloween mirror ghouls anyone?
    56 Posts 18 Posters 63.4k Views 19 Watching
    • bheplerB Offline
      bhepler Module Developer @strawberry 3.141
      @strawberry-3.141 You’re going to turn me into a Javascript developer with crazy talk like that.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @bhepler
        @bhepler that’s what i currently come up with
            module: "helloworld",
            position: "fullscreen_below",
                text: "<video id='halloween_player'></video><script>console.log('init'); var halloween_videos = ['http://techslides.com/demos/sample-videos/small.mp4', 'http://vo.fod4.com/v/9727363b6d/v1280-q2.mp4']; var halloween_index = 0; function playHalloweenVideos(){ console.log('play'); if(halloween_index >= halloween_videos.length){ halloween_index = 0; } var player = document.getElementById('halloween_player'); player.src = halloween_videos[halloween_index++]; player.addEventListener('ended', playHalloweenVideos); player.play(); } playHalloweenVideos();</script><img src='test.png' onload='console.log(\"test\"); eval(document.getElementById(\"halloween_player\").nextSibling.innerHTML); document.removeChild(this);'"
        but i’m not able to eval in my fake img tag, however if you enter this command in the electron console it works
        eval(document.getElementById("halloween_player").nextSibling.innerHTML);
        • F Offline
          frog
          • F Offline
            frog
            I’m trying to loop a video using the following:
               module: ‘helloworld’,
               position: ‘fullscreen_below’,
                  text: “<video src=‘vendor/skelloop.mp4’ autoplay loop; position:absolute; top:100%;left:50%; height:200%’></video>”
            but it just stops after the first run. I’m using the OMXplayer which I would have thought would have taken the loop parameter - but it seems it doesn’t. Anyone have an idea how I can fix this?
            • bheplerB Offline
              bhepler Module Developer @frog
              @frog You seem to be missing the style='position... part.
              So:
                    text: “<video src=‘vendor/skelloop.mp4’ autoplay loop style='position:absolute; top:100%;left:50%; height:200%’></video>”
              F 1 Reply Last reply Reply Quote 2
              • F Offline
                frog @bhepler
                @bhepler yup, that dit it. Thanks!
                • N Offline
                  nuckinfutz
                  is there a way to use a variable in the video file name? This is so close to what I want it hurts. What I want to do is play a random video from a specific location. I will be creating the videos so I will have complete control over the video naming and encoding.
                    makersworkbench
                    Sorry for resurrecting an old thread, but I have been trying to figure this out on my own for over a week now. How would I use a PING (ultrasonic) sensor to trigger the mmm-podcast module to make the jump scare happen? Python I can write but I am a javascript noob, and that is why I am having issues here.
                    So basically I want the PING sensor to trigger and play the video file full screen with audio after it senses someone x-distance away for X number of seconds. Very bad psudo code below.
                    when distance from sensor = 24-inches for 10-seconds
                    play scare animation using mmm-podcast
                    return to MagicMirror screen
                    wait 60-seconds before arming ping sensor again
                      Bruno
                      Guys,
                      How did you manage to play a local video on the Pi with this module?
                      I am trying to make the halloween ghoul video (maybe a little late). I can get some video to play if the video is online. But if the video is on a directory on my raspberry pi I can’t.
                      In this topic all the “text” tag on the helloworld is blank because it is html tag so it gets “interpreted” by my browsers. I’ll try to post my “text” tag in non-HTML way, so you guys can analyse it (I took off the “minor than” sign from the tags: video, src and /video)
                      Heres my config:
                                  position: "middle_center",
                                      text: "video id=\"homevideo\" width=\"100%\" autoplay autobuffer> source src=\"http://clips.vorwaerts-gmbh.de/VfE_html5.mp4\" type=\"video/mp4\" /> /video>"
                      Above is an example if a simples mp4 video online: http://clips.vorwaerts-gmbh.de/VfE_html5.mp4
                      How do I change to a local mp4 file in my Pi? I tryed src="/home/pi/path/to/my/file.mp4" but no success… any ideas?
                      S Mykle1M 2 Replies Last reply Reply Quote 0
                        sdetweil @Bruno
                        @Bruno said in Halloween mirror ghouls anyone?:
                        Guys,
                        Heres my config:
                        Path has got to be in the mm folder tree or linked to from there
                        /modules/module name/filename.mp4
                          Mykle1 Project Sponsor Module Developer @Bruno
                          If you are trying to make a module that plays local videos or if you’re just looking for a module that plays local videos then have a look at this module
                          https://github.com/mykle1/MMM-EasyBack
                          I just downloaded your example video and it works perfectly well with this module, locally.
                          B B 2 Replies Last reply Reply Quote 0
                            Bruno @Mykle1
                            @Mykle1 said in Halloween mirror ghouls anyone?:
                            Nice!!! I’ll give it a try. It’s nice that I can define width and height!!! Thanks!!
                              You’re welcome, mate. If you are still wanting to create your own module, feel free to take whatever you find useful from the module and use it in your own.
                                BD0G @Mykle1
                                @Mykle1
                                This is so weird!
                                I installed MMM-EasyBack as per the instructions.
                                Copied a small Halloween Video in the MagicMirror/Modules/MMM-EasyBack/Videos folder. The file is named HalloweenMM.mp4. Its 15 MB. So pretty small.
                                Here are my config.js entries for the module.
                                    module: 'MMM-EasyBack',
                                    position: 'middle_center',
                                       // bgName: "Example.jpg",   // "Example.jpg", the file name of your background image (case sensitive)
                                        videoName: "HalloweenMM.mp4",       // "baboon.mp4",         // file name of your local video
                                        height: "1920px",    // your display's resolution in pixels. Enter in config.js
                                        width: "1080px",     // your display's resolution in pixels. Enter in config.js
                                I completely removed the section about Youtube ID , etc . When I launch the MM interface it contunually comes up with the YouTube Video by David Snow found here https://www.youtube.com/watch?v=So3vH9FY2H4
                                There is no reference that I can find to that video at all.
                                The YouTube ID that is referenced by this video is the same one that was in the original configuration file.
                                  sdetweil @BD0G
                                  @BD0G open the developers window, ctrl-shift-i on the mm keyboard, and select the console tab and then enter hall in the filter field
                                  see if there are any errors (usually red text)
                                  case matters
                                    BD0G @sdetweil
                                    @sdetweil Thanks Sam.
                                    I went into the MMM-EasyBack.js file and altered it to reflect the video HalloweenMM.mp4 rather than within the config.js file. I also removedt the hard coded Youtube ID that was in the MMM-EasyBack.js file.
                                    Now it plays the Halloween file , but I cannot control the sizing of the video and it takes up just about the entire screen.
                                    Module.register("MMM-EasyBack", {
                                        defaults: {
                                            bgName: "",         // .jpg, .gif, .png, Full screen animated gifs too!
                                            videoName: "HalloweenMM.mp4",     // your local picture files go in "images" folder of MMM-EasyBack
                                            youTubeID: "",      // YouTube ID from the YouTube url
                                            height: "800px",   // your display's resolution in pixels. Enter in config.js
                                            width: "600px",    // your display's resolution in pixels. Enter in config.js
                                            animationSpeed: "0",
                                            updateInterval: 60 * 60 * 1000,
                                      sdetweil @BD0G
                                      @BD0G do not edit the source file
                                      all config goes in the config.js
                                      no idea on the youtube stuff, maybe its the default for a youtube search…
                                      the author is not available currently.
                                        BD0G
                                        i am going to just modify the included MMM-EasyBack.css file to see if I can shrink it. Yeah that works.
                                        .MMM-EasyBack .photo {
                                          width: 100%;               /* size the picture */
                                        .MMM-EasyBack #video {
                                          width: 50%;
                                          height: 50%;
                                        .MMM-EasyBack .iframe {
                                          margin-top: 50px;
                                                margin-bottom: 0px;
                                                margin-left: 50px;
                                                margin-right: 0px;
                                          sdetweil @BD0G
                                          @BD0G don’t modify the css file
                                          the system design is that css/custom.css will allow you to override any setting set by a module or the main.css file
                                          so you put those entries in custom.css
                                          all this no editing means the author can release updates and nothing u did is impacted
                                            BD0G @sdetweil
                                            @sdetweil said in Halloween mirror ghouls anyone?:
                                            Gotcha!
                                            • 3 / 3
