    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 921.7k Views 74 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @mrdenmark
      @mrdenmark well, you COULD go into the .njk template file and put in an <hr> just above this part
              {# Daily #}
              {% if config.showDailyForecast %}
      or give the forecast-item hourly classes a border-top: 1px solid #cccvia css.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        mrdenmark @lavolp3
        @lavolp3
        it worked,thankyou:)
        • lavolp3L Offline
          @mrdenmark thinking about that again the better way would be to give the daily forecast part a border-top in your custom css. That way you would not have to struggle when you want to update the module.
          Let me know if you need help with that.
            BD0G
            I do. :)
            • lavolp3L Offline
              lavolp3 Module Developer @BD0G
              @BD0G
              The css way is not as easy as I would have assumed.
              All the elements in the forecast belong have “.forecast-item .hourly” classes so are not distinguishable.
              I currently don’t know of a pure css way to get in between them and give the first daily forecast a margin or a border.
              • T Offline
                trividar
                It’s possible to add animated .mov format icons to this module? I have found some amazing icons, but just bevor I buy it i will be shure that it will be working… animated weather icons…
                THX!
                • T Offline
                  TyFusion
                  Hey guys,
                  I’m trying to use this model and this stucks in loading :
                  		  module: "MMM-DarkSkyForecast",
                  		  header: "Weather",
                  		  classes: "default everyone",
                  		  disabled: false,
                  		    		apikey: "xxxxx",
                  		    		latitude: "39,462900",
                  		    		longitude: "-8.473200",
                  		    		iconset: "4c",
                  		    		concise: false,
                  		    		forecastLayout: "table"
                  What 's the problem here?
                  LordyL T 2 Replies Last reply Reply Quote 0
                  • LordyL Offline
                    Lordy @TyFusion
                    @TyFusion said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    MMM-DarkSkyForecast
                    Installation
                    1)Navigate into your MagicMirror modules folder and execute
                    git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git.
                    2)Enter the new MMM-DarkSkyForecast directory and execute npm install.                                                       3) reboot
                    Did you follow these instructions?
                    • T Offline
                      ttarzan @TyFusion
                      @TyFusion I think you have to exchange the decimal point for a dot at latitude.
                      Try “latitude: “39.462900”,”
                      LordyL 1 Reply Last reply Reply Quote 1
                      • LordyL Offline
                        Lordy @ttarzan
                        @ttarzan
                        You might be right, I overlook that tonight.
                        • drippyerD Offline
                          drippyer
                          Just wanted to let folks know that DarkSky is no longer accepting new users to the API now that they have been acquired by Apple.
                            Yeah… not sure what I’m going to do about this yet… Need to rewrite my weather module AGAIN due to API going belly-up. Any suggestions on a good, free API?
                            H M 2 Replies Last reply Reply Quote 1
                            • H Offline
                              Hadr1en Project Sponsor @j.e.f.f
                              @j-e-f-f maybe try yr.no ? it’s free :)
                              • N Offline
                                numb3rs
                                https://openweathermap.org/api
                                  j.e.f.f Project Sponsor Module Developer @Hadr1en
                                  @Hadr1en @numb3rs Thanks! Will look into both of these.
                                  • T Offline
                                    trividar @j.e.f.f
                                    @j-e-f-f it is possible to use animated icons (4c) for the main icon?
                                      PH1TCH
                                      @j-e-f-f Great module, definitely my favorite weather module so far!
                                      2 things would make it perfect in my opinion: Feels like temperature and sunrise/sunset data.
                                      Do you have any plans to add those in the future?
                                      Thank You!
                                        michaelsfp @j.e.f.f
                                        @j-e-f-f The best replacement for DarkSky that I’ve found is https://www.climacell.co/weather-api/ since its hyper-local. Free tier gets you 30,000 calls/month.
                                        lavolp3L 1 Reply Last reply Reply Quote 1
                                        • Cr4z33C Offline
                                          Cr4z33 @drippyer
                                          @drippyer said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                          Maybe I shouldn’t say it, but… you can find many working DarkSky API codes around (that can be used simultaneously by more than one user).
                                          Just do a proper search in Google Images and here you go. 😂
                                          • lavolp3L Offline
                                            lavolp3 Module Developer @michaelsfp
                                            @michaelsfp said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                            This one sounds really interesting! Thanks! Seems to have minutely data for Europe as well which is rare.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
