    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.5k Views 74 Watching
      BD0G
      This is the exact way I installed as per the instructions upon the GitHub.com page for MMM-DarkSkyForecast
      Installation
      Navigate into your MagicMirror modules folder and execute
      git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git.
      Enter the new MMM-DarkSkyForecast directory and execute npm install.
      It created a directory with a lowercase d within the name MMM-DarkSkyForecast under /MagicMirror/modules
        sdetweil @BD0G
        @BD0G ok, never seen that happen
          BD0G
          Wow! Now I see the weather! Now I will change the Celsius to Fahrenheit and wind speed to Miles Per Hour instead of Kilometers Per Hour
            sdetweil @BD0G
            @BD0G cool…
              mrdenmark
              @j-e-f-f
              is it possible to have a space/blank line between the hourly and daily forecasts in the table view?
                sdetweil @mrdenmark
                  mrdenmark @sdetweil
                  @sdetweil sorry,posted the question to the wrong person-changed now!
                  • lavolp3L Offline
                    lavolp3 Module Developer @mrdenmark
                    @mrdenmark well, you COULD go into the .njk template file and put in an <hr> just above this part
                            {# Daily #}
                            {% if config.showDailyForecast %}
                    or give the forecast-item hourly classes a border-top: 1px solid #cccvia css.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                      mrdenmark @lavolp3
                      @lavolp3
                      it worked,thankyou:)
                      • lavolp3L Offline
                        @mrdenmark thinking about that again the better way would be to give the daily forecast part a border-top in your custom css. That way you would not have to struggle when you want to update the module.
                        Let me know if you need help with that.
                          BD0G
                          I do. :)
                          • lavolp3L Offline
                            lavolp3 Module Developer @BD0G
                            @BD0G
                            The css way is not as easy as I would have assumed.
                            All the elements in the forecast belong have “.forecast-item .hourly” classes so are not distinguishable.
                            I currently don’t know of a pure css way to get in between them and give the first daily forecast a margin or a border.
                            • T Offline
                              trividar
                              It’s possible to add animated .mov format icons to this module? I have found some amazing icons, but just bevor I buy it i will be shure that it will be working… animated weather icons…
                              THX!
                              • T Offline
                                TyFusion
                                Hey guys,
                                I’m trying to use this model and this stucks in loading :
                                		  module: "MMM-DarkSkyForecast",
                                		  header: "Weather",
                                		  classes: "default everyone",
                                		  disabled: false,
                                		    		apikey: "xxxxx",
                                		    		latitude: "39,462900",
                                		    		longitude: "-8.473200",
                                		    		iconset: "4c",
                                		    		concise: false,
                                		    		forecastLayout: "table"
                                What 's the problem here?
                                LordyL T 2 Replies Last reply Reply Quote 0
                                • LordyL Offline
                                  Lordy @TyFusion
                                  @TyFusion said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                  MMM-DarkSkyForecast
                                  Installation
                                  1)Navigate into your MagicMirror modules folder and execute
                                  2)Enter the new MMM-DarkSkyForecast directory and execute npm install.                                                       3) reboot
                                  Did you follow these instructions?
                                  • T Offline
                                    ttarzan @TyFusion
                                    @TyFusion I think you have to exchange the decimal point for a dot at latitude.
                                    Try “latitude: “39.462900”,”
                                    LordyL 1 Reply Last reply Reply Quote 1
                                    • LordyL Offline
                                      Lordy @ttarzan
                                      @ttarzan
                                      You might be right, I overlook that tonight.
                                      • drippyerD Offline
                                        drippyer
                                        Just wanted to let folks know that DarkSky is no longer accepting new users to the API now that they have been acquired by Apple.
                                          Yeah… not sure what I’m going to do about this yet… Need to rewrite my weather module AGAIN due to API going belly-up. Any suggestions on a good, free API?
                                          H M 2 Replies Last reply Reply Quote 1
                                          • H Offline
                                            Hadr1en Project Sponsor @j.e.f.f
                                            @j-e-f-f maybe try yr.no ? it’s free :)
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
