Don't know how to configure a module
5 Posts 2 Posters 1.2k Views 2 Watching
  • F Offline
    FLOW THE NOOB
    I want to use a 3rd party module in the mirror but its description lacks in an example of how to set it up.
    It’s a module that displays Barcelona TMB metro train and bus times. https://github.com/jaumebosch/MMM-TMB
    I already followed the steps required but the module keeps “loading” and no time tables show up.
    Here is the code that I put in the “modules” array:
    module: “MMM-TMB”,
    position: “bottom_right”, // This can be any of the regions.
    appId: “e667ba4d”,
    appKey: “4cce2cd5c009e7b2368a61f89e909733”,
    busStopCode: “000921”,
                // See below for configurable options
    It’s a bit different to the one posted by its’ creator because that one made the whole MagicMirror program crash.
    I’d appreciate any advice.
    M 2 Replies Last reply Nov 16, 2019, 9:32 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @FLOW THE NOOB
      @FLOW-THE-NOOB
      Assuming that your appID and appKey are both valid (I suggest you verify them both), have you tried any other bus stop codes?
      I tried the the stopUrl for “stops” from the node_helper.js and this was the response:
      HTTP Status 404 - Could not find resource for relative : /1.0/ibus/stops/000921
        @FLOW-THE-NOOB
        Looked into this a little further. I’m pretty sure the problem lies with the busStopCode or the module is not behaving as expected. If you empty the busStopCode, as seen below, the module starts displaying data. Perhaps this will put you on the right track to resolving your issue./
          disabled: f,
        module: 'MMM-TMB',
        position: 'top_right', // This can be any of the regions.
        appId: 'e667ba4d',
        appKey: '4cce2cd5c009e7b2368a61f89e909733',
        busStopCode: '',
        Returns this:
        • F Offline
          FLOW THE NOOB
          Thank you very much! I put only 3 digits of the bus stop code and it works perfectly.
          M 1 Reply Last reply Nov 17, 2019, 4:02 PM Reply Quote 0
            @FLOW-THE-NOOB said in Don't know how to configure a module:
            Ahh, as I expected. Excellent. Glad you have it working now. :-)
