    Halloween mirror ghouls anyone?
    56 Posts 18 Posters 67.4k Views 19 Watching
      rvdgeer @rvdgeer
      Markdown is not available from my Android smartphone. I don’t have the correct character available…
      And it’s a little too much to ask, to look-up the character on the web, so I can copy it…
      J BKeyportB 2 Replies Last reply Reply Quote 1
        jtyle6 @rvdgeer
        @rvdgeer said in Halloween mirror ghouls anyone?:
        Markdown forms an Android phone
          Mitchfarino Module Developer @Jopyth
          @Jopyth Have you had any luck with this mate?
          I haven’t looked at it for a while, have had a few things going on so haven’t had chance
            Jopyth Moderator @Mitchfarino
            @Mitchfarino did not have the time for it. I will see if I get to it, when I get back from vacation in one week.
              bhepler Module Developer
              I experimented with this a bit yesterday. Thanks to @rvdgeer for the hint and @Jopyth for the initial code to start.
              I ripped a YouTube video to disk and uploaded it to my Pi, putting it in the vendor folder. Adding this to my config.js was surprisingly effective (the rotate 90 is due to the video being designed to be projected on a window):
              {     module: "helloworld",
                    position: "fullscreen_below",
                              text: "<video src='vendor/halloween.mp4' autoplay loop style='transform:rotate(90deg); position:absolute; top:50%;left:30%; height:50%'></video>"
              M 2 Replies Last reply Reply Quote 1
                Mitchfarino Module Developer @bhepler
                @bhepler What video did you use? Sorry I missed the link
                How did you rip it from YouTube?
                • Y
                  yawns Moderator @Mitchfarino
                  @Mitchfarino
                  check your chat ;)
                    Mitchfarino Module Developer @yawns
                    @yawns Awesome, thank you!
                      @bhepler Is there a way to loop through a number of videos, rather than just the one on repeat?
                        bhepler Module Developer @Mitchfarino
                        @Mitchfarino Presumably you can inject some scripting to define an array of video files and then call a function to play the next file in the array. If you call that function from the onended() event in the VIDEO tag you should be able to get 90% of the way there.
                          @bhepler Any idea how to do that?
                            @Mitchfarino StackExchange had a pretty good start.
                            Based upon the fact that the text value includes the HTML tag , you can probably put another tag in there to handle your script. Probably. I haven’t tried it. You may end up making some fancy character escaping in order to get it to work properly, but it should be possible. If I get the chance I’ll play with it.
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @bhepler
                              @bhepler the problem is to get the script tag evaluated, when it gets inserted as text, i have a script that is working, but still stuck on the evaluation. It’s probably easier to just create a new module, than finding another hacky workaround
                                bhepler Module Developer @strawberry 3.141
                                @strawberry-3.141 You’re going to turn me into a Javascript developer with crazy talk like that.
                                • strawberry 3.141S
                                  @bhepler that’s what i currently come up with
                                          text: "<video id='halloween_player'></video><script>console.log('init'); var halloween_videos = ['http://techslides.com/demos/sample-videos/small.mp4', 'http://vo.fod4.com/v/9727363b6d/v1280-q2.mp4']; var halloween_index = 0; function playHalloweenVideos(){ console.log('play'); if(halloween_index >= halloween_videos.length){ halloween_index = 0; } var player = document.getElementById('halloween_player'); player.src = halloween_videos[halloween_index++]; player.addEventListener('ended', playHalloweenVideos); player.play(); } playHalloweenVideos();</script><img src='test.png' onload='console.log(\"test\"); eval(document.getElementById(\"halloween_player\").nextSibling.innerHTML); document.removeChild(this);'"
                                  but i’m not able to eval in my fake img tag, however if you enter this command in the electron console it works
                                  eval(document.getElementById("halloween_player").nextSibling.innerHTML);
                                  • F
                                    frog
                                    • F
                                      frog
                                      I’m trying to loop a video using the following:
                                         module: ‘helloworld’,
                                         position: ‘fullscreen_below’,
                                            text: “<video src=‘vendor/skelloop.mp4’ autoplay loop; position:absolute; top:100%;left:50%; height:200%’></video>”
                                      but it just stops after the first run. I’m using the OMXplayer which I would have thought would have taken the loop parameter - but it seems it doesn’t. Anyone have an idea how I can fix this?
                                        bhepler Module Developer @frog
                                        @frog You seem to be missing the style='position... part.
                                        So:
                                              text: “<video src=‘vendor/skelloop.mp4’ autoplay loop style='position:absolute; top:100%;left:50%; height:200%’></video>”
                                        F 1 Reply Last reply Reply Quote 2
                                        • F
                                          frog @bhepler
                                          @bhepler yup, that dit it. Thanks!
                                          • N
                                            nuckinfutz
                                            is there a way to use a variable in the video file name? This is so close to what I want it hurts. What I want to do is play a random video from a specific location. I will be creating the videos so I will have complete control over the video naming and encoding.
                                            • 2 / 3
