    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 543.8k Views 29 Watching
      BD0G @Mykle1
      @Mykle1 When can you be here? LOL.
        BD0G @Mykle1
        @Mykle1 If I get stuck I always ask for assistance and realize that we all cannot know everything about anything. We are all learning. I appreciate your willingness to help ! I am sure you will see lots mode posts by me. :)
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @BD0G
          @BD0G
          I’m here. I’ll send you a private message
          • cowboysdudeC
            We are all here…
            • Mykle1M
              @cowboysdude said in MMM-Lunartic:
              We are all here…
              Now I’m here. Now I’m there.
              • cowboysdudeC
                You are truly an International man of mystery.
                  BD0G @cowboysdude
                  @cowboysdude He helped me resolve the issue so its looking goooooooood!
                  • V
                    Vauxdvihl
                    Unfortunately no image is shown
                    And i am not able to reach the linked homepage here (location germany)
                    Is there a workaround?
                    Thanks a lot
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Vauxdvihl
                      @Vauxdvihl said in MMM-Lunartic:
                      Yes, the API is down. However, there is a workaround. (temporary fix)
                      1. Do a “git pull” in the MMM-Lunartic directory to make sure the module is up to date
                      2. Rename your current MMM-Lunartic.js file to MMM-Lunartic.bak
                      3. You will now notice a folder named “temporary fix” inside the module folder. Inside the “temporary fix” folder is another MMM-Lunartic.js file. Copy and paste that to the root of the MMM-Lunartic folder.
                      4. Restart MM
                      • V
                        Vauxdvihl
                        @Mykle1
                        :thumbs_up:
                        Thanks a lot
                        it works
                        • Mykle1M
                          Thanks a lot
                          You’re welcome. :thumbsup:
                          it works
                          A minor miracle. :-)
                          • E
                            Egnos @Mykle1
                            @Mykle1 said in MMM-Lunartic:
                            4. Restart MM
                            Hi @Mykle1,
                            I tried to do your work around but I only see this writing: “When the Moon hits your eye…”
                            This is my configuration:
                            			disabled: false,
                            			module: 'MMM-Lunartic',
                            			//position: 'bottom_center', // Best in left, center, or right regions
                            			pages: {Prova: "top_left"},
                            				mode: "rotating", // rotating or static
                            				image: "current", // animation, current, DayNight or static
                            				distance: "miles", // miles or km
                            				sounds: "yes", // howling wolf, only on a full moon
                            				useHeader: false, // true if you want a header
                            				header: "The Lunartic is in my head", // Any text you want
                            				maxWidth: "300px",
                            				animationSpeed: 0,
                            				rotateInterval: 15000,
                            Could you help me?
                            Many thanks!
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Egnos
                              @Egnos
                              I’m surprised you even saw “When the Moon hits your eye…” at all.
                              I don’t know where this came from --> pages: {Prova: “top_left”},
                              This works:
                              			disabled: false,
                              		//	pages: {Prova: "top_left"},
                              				maxWidth: "300px",
                              				animationSpeed: 0,
                              • E
                                Egnos @Mykle1
                                Thanks @Mykle1.
                                My MM has multiple pages and uses the “MMM-Page-Selector” module.
                                Using the configuration below I should display your module on the “Prova” page, but showing only "When the Moon hits your eye…”
                                All other modules (about 21 …) respect this rule …
                                Could you do something?
                                Thanks a lot!
                                • Mykle1M
                                  @Egnos
                                  Well, first a question. Does it work with the default config entry after you’ve done the temporary fix?
                                  • E
                                    Egnos @Mykle1
                                    @Egnos
                                    Yes, if you comment the line
                                    the module seems to work correctly.
                                    I did this test using a new “config.js”, without the other 21 modules.
                                    It is also possible that Lunartic conflicts with some other module.
                                    Here are the modules I installed:
                                    MMM-iFrame-Ping
                                    MMM-Page-Selector
                                    MM-orrery
                                    MMM-DarkSkyForecast
                                    MMM-ISS
                                    MMM-RTSPStream
                                    planetrise
                                    MMM-EARTH-Live
                                    MMM-ISS-Live
                                    MMM-Screencast
                                    MMM-Formula1
                                    MMM-Lunartic
                                    MMM-SoccerLiveScore
                                    MMM-Globe
                                    MMM-MyCommute
                                    mmm-suncalc
                                    MMM-GoogleMapsTraffic
                                    MMM-page-indicator
                                    MMM-Voice-Commands
                                    Thanks.
                                    • Mykle1M
                                      @Egnos said in MMM-Lunartic:
                                      Sure, it’s possible. Anything is possible. However, Lunartic works, without issue, with every other module (as far as I know). I don’t use MMM-Page-Selector. I use Hello-Lucy for my page selections and Lunartic lives happily there. No issues. No conflicts.
                                      With that said, I’ll see if I can discover anything.
                                      In the meantime, you can uncomment the pages: {Prova: "top_left"}, line and start you mirror with npm start dev. Report any errors from the dev console that appears.
                                      • E
                                        Egnos @Mykle1
                                        @Mykle1 Hello Lucy allows you to create pages like MMM-Page Selector?
                                        Is it possible to change the pages automatically after a set time?
                                        Many thanks @Mykle1.
                                        PS: I try your advice as soon as possible!👍
                                        • Mykle1M
                                          @Egnos
                                          I’m not familiar with MMM-PageSelector so I don’t know how things work within that module.
                                          Changing pages after a set time is not a feature that I have a use for. I can simply change a page with a voice command any time I want. Feel free to fork the module and make any changes your like. Send a PR if you like.
                                          I think there are already modules that might do that.
                                          • E
                                            Egnos
                                            HI @Mykle1
                                            I don’t know why but the module started working!
                                            I have some questions:
                                            • How should I modify the config.js to not display the image of the moon but only the text?
                                            • I am Italian, how can I translate the text?
                                            • If you want to use “Hello Lucy” to call up the page with my voice, could you recommend a good microphone?
                                            Thank you so much for your patience.:winking_face:
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
