    Electron Browser outdated?
    25 Posts 7 Posters 11.1k Views 7 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @rudibarani
      @rudibarani how can I update electron?
        @rudibarani I have a Mac mini
        • lavolp3L Offline
          lavolp3 Module Developer @Stoffbeuteluwe
          @Stoffbeuteluwe go into the MagicMirror home folder and execute
          npm install electron@latest
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          StoffbeuteluweS 3 Replies Last reply Reply Quote 2
          • lavolp3L Offline
            Testing now electron@6.0.10 on a
            Raspberry Pi 4 with
            npm@6.10.2 and
            node@10.15.2
            Will report back as soon as I have something
              Stoffbeuteluwe Project Sponsor @lavolp3
              @lavolp3 thanks
                @lavolp3 works fine on Mac
                    I have submitted change to upgrade to version 6.0.12 on next update
                    • V Offline
                      Vauxdvihl
                      @lavolp3 said in Electron Browser outdated?:
                      Hi all,
                      i have updated the electron like above written (because i had the same issue)
                      After update nothing works
                      Error code
                      pi@raspberrypi:~/MagicMirror $ npm start dev
                      > magicmirror@2.9.0 start /home/pi/MagicMirror
                      > sh run-start.sh "dev"
                      /home/pi/MagicMirror/node_modules/electron/index.js:14
                          throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
                      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                          at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
                          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
                          at Module.require (internal/modules/cjs/loader.js:692:17)
                          at require (internal/modules/cjs/helpers.js:25:18)
                          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.9.0 start: `sh run-start.sh "dev"`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.9.0 start script.
                      npm ERR!     /home/pi/.npm/_logs/2019-11-22T22_16_40_595Z-debug.log
                      Can please somebody help me
                      Thanks a lot
                      Regards
                        sdetweil @Vauxdvihl
                        @Vauxdvihl
                        yes, lets try something not so new…
                        do
                        rm -rf node_modules/electron
                        npm install electron@6.0.12
                        note that for other modules, you may also have to run electron-rebuild
                        • V Offline
                          Vauxdvihl
                          @sdetweil said in Electron Browser outdated?:
                          Thanks a lot
                          Works find
                            Sorry about reviving an old thread but I thought you and others might want to know
                            Bro, I went ahead and installed npm install electron@latest (11.3.0) as an experiment. Both my MMM-ISS-Live and EARTH-Live modules were affected by electron. It appears the latest version of electron has fixed the problem, at least with these two modules
                              sdetweil @Mykle1
                              @mykle1 the current mm develop branch has a number of changes, including moving up to electron 11.2.1
                              i would suggest trying that too…
                              • karsten13K Online
                                karsten13 @sdetweil
                                there is already a pull request which includes the update to 11.3.0, should be merged within the next days into develop
