    Electron Browser outdated?
    25 Posts 7 Posters 11.3k Views 7 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @lavolp3
      @lavolp3 thanks
      • StoffbeuteluweS
        @lavolp3 works fine on Mac
        • StoffbeuteluweS
            I have submitted change to upgrade to version 6.0.12 on next update
            • V
              Vauxdvihl
              @lavolp3 said in Electron Browser outdated?:
              npm install electron@latest
              Hi all,
              i have updated the electron like above written (because i had the same issue)
              After update nothing works
              Error code
              pi@raspberrypi:~/MagicMirror $ npm start dev
              > magicmirror@2.9.0 start /home/pi/MagicMirror
              > sh run-start.sh "dev"
              /home/pi/MagicMirror/node_modules/electron/index.js:14
                  throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                  at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
                  at Module.require (internal/modules/cjs/loader.js:692:17)
                  at require (internal/modules/cjs/helpers.js:25:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.9.0 start: `sh run-start.sh "dev"`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.9.0 start script.
              npm ERR!     /home/pi/.npm/_logs/2019-11-22T22_16_40_595Z-debug.log
              Can please somebody help me
              Thanks a lot
              Regards
                sdetweil @Vauxdvihl
                @Vauxdvihl
                yes, lets try something not so new…
                do
                rm -rf node_modules/electron
                npm install electron@6.0.12
                note that for other modules, you may also have to run electron-rebuild
                • V
                  Vauxdvihl
                  @sdetweil said in Electron Browser outdated?:
                  Thanks a lot
                  Works find
                  • Mykle1M
                    Sorry about reviving an old thread but I thought you and others might want to know
                    Bro, I went ahead and installed npm install electron@latest (11.3.0) as an experiment. Both my MMM-ISS-Live and EARTH-Live modules were affected by electron. It appears the latest version of electron has fixed the problem, at least with these two modules
                      sdetweil @Mykle1
                      @mykle1 the current mm develop branch has a number of changes, including moving up to electron 11.2.1
                      i would suggest trying that too…
                      • karsten13K
                        karsten13 @sdetweil
                        there is already a pull request which includes the update to 11.3.0, should be merged within the next days into develop
