    MMM-MyCommute - API Calls and Quota
    9 Posts 6 Posters 2.8k Views 6 Watching
    • ooom416354O Offline
      ooom416354 @sdetweil
      @sdetweil that is great, thank you. by chance just for my learning, where is it in the code? thanks again !
      • lavolp3L Offline
        lavolp3 Module Developer @ooom416354
        @ooom416354 Look into line 173 of the MMM-MyCommute.js
          getData: function() {
            //only poll if in window
            if ( this.isInWindow( this.config.startTime, this.config.endTime, this.config.hideDays ) ) {
              //build URLs
        Above that you can find the isInWindow()-function that checks if current time is between start and end time.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        ooom416354O 1 Reply Last reply Reply Quote 1
          ooom416354 @lavolp3
          @lavolp3 Thanks so much for the details!
            I’m the author of this plugin and I can confirm that the module will not poll for data outside the window you set. I designed it this way specifically to deal with Google’s quota.
            • H Offline
              hermlam @j.e.f.f
              @j-e-f-f
              Hi, that want I am trying, to reduce the API calls. but I have problem with it.
              My mirror stop showing MMM-Commute in the evening but doesn’t start in the morning… See my config.js:
              Thanks,
              Herman
              module: ‘MMM-MyCommute’,
              position: ‘top_left’,
              header: ‘Verkeer’,
              classes: ‘default everyone’,
              apikey: ‘xxx’,
              origin: ‘87 Verisstraat, Hoofddorp, 2132 PC’,
              startTime: ‘05:45’,
              endTime: ‘23:00’,
              // showSummary: true,
              // hideDays: [0,6],
              destinations: [
              destination: ‘116 La Guardiaweg, Amsterdam, 1043 DL’,
              label: ‘UWV’,
              J T 2 Replies Last reply Reply Quote 0
                j.e.f.f Project Sponsor Module Developer @hermlam
                @hermlam I haven’t looked at this code for a long time and it’s quite possible this module no longer works properly. I believe there are newer forks you can try that are currently under active development.
                Try here:
                https://github.com/jclarke0000/MMM-MyCommute/network/members
                • T Offline
                  trawson @hermlam
                  @hermlam I am having this same issue, at least since the most recent MM update. Have you found a solution yet?
