    MMM - Spotify
    22 Posts 3 Posters 6.2k Views 3 Watching
      sdetweil @ELMAGO
      @ELMAGO said in MMM - Spotify:
      I would like it to be displayed only for some device, could you help me?
      could you explain that a little more please
      • E Offline
        ELMAGO
        Hello
        I would like that if the name of the device is for example, DESKTOP-GLTBMFB as on the image, the module does not appear.
        alt text
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @ELMAGO
          @ELMAGO Ok… let me feed that back…
          you have multiple devices capable of playing spotify music, and you would like to prevent/limit the active playing display to just certain devices (your phone, but not your teenagers for example).
          • E Offline
            ELMAGO
            @sdetweil said in MMM - Spotify:
            Indeed, I have several devices. I use my computer at work, for example, and I do not want it to work on my MagicMirror at home.
              sdetweil @ELMAGO
              @ELMAGO got it… I don’t know how to solve the problem, but didn’t understand your need at the beginning.
              • E Offline
                ELMAGO
                ok thanks
                  A Former User @ELMAGO
                  @ELMAGO
                  Isn’t this working?
                  • E Offline
                    ELMAGO
                    I did not use this module in fact, I install it and I come back to you.
                    Thank you
                    • E Offline
                      ELMAGO @Guest
                      @Sean
                      I just finished the installation.
                      If I do not put anything in this option, I see what Diffuse Spotify, but if I use this option :
                      module: “MMM-Spotify”,
                      position: “top_center”,
                      style: “default”, // “default” or “mini” available
                      control: “hidden”, //“default”, “hidden” available
                      updateInterval: 100,
                      onStart: null, // disable onStart feature with null
                      allowDevices: [“Galaxy S10”], //If you want to limit devices to display info, use this.
                      // allowDevices: [“RASPOTIFY”, “My iPhoneX”, “My Home speaker”],
                      I have the Spotify logo but that’s it.
                      An idea ?
                        @ELMAGO
                        any of your spotify player needs to be turned on. did u install raspotify?
