    MMM - Spotify
    22 Posts 3 Posters 7.5k Views 3 Watching
      sdetweil @ELMAGO
      @ELMAGO said in MMM - Spotify:
      I would like it to be displayed only for some device, could you help me?
      could you explain that a little more please
      • E Offline
        ELMAGO
        Hello
        I would like that if the name of the device is for example, DESKTOP-GLTBMFB as on the image, the module does not appear.
        alt text
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @ELMAGO
          @ELMAGO Ok… let me feed that back…
          you have multiple devices capable of playing spotify music, and you would like to prevent/limit the active playing display to just certain devices (your phone, but not your teenagers for example).
          • E Offline
            ELMAGO
            @sdetweil said in MMM - Spotify:
            Indeed, I have several devices. I use my computer at work, for example, and I do not want it to work on my MagicMirror at home.
              sdetweil @ELMAGO
              @ELMAGO got it… I don’t know how to solve the problem, but didn’t understand your need at the beginning.
              • E Offline
                ELMAGO
                ok thanks
                  A Former User @ELMAGO
                  @ELMAGO
                  Isn’t this working?
                  • E Offline
                    ELMAGO
                    I did not use this module in fact, I install it and I come back to you.
                    Thank you
                    • E Offline
                      ELMAGO @Guest
                      @Sean
                      I just finished the installation.
                      If I do not put anything in this option, I see what Diffuse Spotify, but if I use this option :
                      module: “MMM-Spotify”,
                      position: “top_center”,
                      style: “default”, // “default” or “mini” available
                      control: “hidden”, //“default”, “hidden” available
                      updateInterval: 100,
                      onStart: null, // disable onStart feature with null
                      allowDevices: [“Galaxy S10”], //If you want to limit devices to display info, use this.
                      // allowDevices: [“RASPOTIFY”, “My iPhoneX”, “My Home speaker”],
                      I have the Spotify logo but that’s it.
                      An idea ?
                        @ELMAGO
                        any of your spotify player needs to be turned on. did u install raspotify?
                        • E Offline
                          ELMAGO @Guest
                          @Sean
                          a player was running, the Galaxy S10 precisely.
                          I just want to make a display of the music that passes on some players.
                          Why need Raspotify?
                            @ELMAGO
                            if u has no need to play spotify on rpi, raspotify is not required.
                            anyway, to get current spotify playback info, one of your spotify player(galaxy s10) should be activated already before MMM-Spotify. The module doesn’t know which player is available until the player is activated.
                            • E Offline
                              ELMAGO @Guest
                              @Sean said in MMM - Spotify:
                              ok, I understand and I do not want to play spotify on this Rasp, I just want a display of music that passes on some players. So why when I do not restrict devices and change device, the module detects it well, whereas when I restrict it there is no display.
                              • E Offline
                                ELMAGO
                                Someone will have an idea?
                                  @ELMAGO
                                  I’ve updated, Update module and try again.
                                        module: "MMM-Spotify",
                                        position: "bottom_right",
                                          allowDevices:["My iPhoneXI Pro"], // < - Change this to your device name.
                                  • E Offline
                                    ELMAGO @Guest
                                    @Sean
                                    Hello
                                    and thank you, how to update the module?
                                      @ELMAGO
                                      git pull in MMM-Spotify directory.
                                      • E Offline
                                        ELMAGO
                                        • E Offline
                                          ELMAGO @Guest
                                          @Sean
                                          Hello
                                          it’s perfect, great. For several devices I have to put a comma and [“XXXX”]?
                                          The Spotify logo, does not disappear?
                                          ? E 2 Replies Last reply Reply Quote 0
                                            @ELMAGO
                                            Yes. ["My iPhoneXI Pro", "DESKTOP-ABCD", "RASPOTIFY"].
                                            You can hide it by CSS or change the logo image file to what you want.
