    MMM - Spotify
    22 Posts 3 Posters 6.0k Views 3 Watching
      sdetweil @ELMAGO
      @ELMAGO got it… I don’t know how to solve the problem, but didn’t understand your need at the beginning.
      • E Offline
        ELMAGO
        @sdetweil said in MMM - Spotify:
        ok thanks
          A Former User @ELMAGO
          @ELMAGO
          Isn’t this working?
          • E Offline
            ELMAGO
            I did not use this module in fact, I install it and I come back to you.
            Thank you
            • E Offline
              ELMAGO @Guest
              @Sean
              I just finished the installation.
              If I do not put anything in this option, I see what Diffuse Spotify, but if I use this option :
              module: “MMM-Spotify”,
              position: “top_center”,
              style: “default”, // “default” or “mini” available
              control: “hidden”, //“default”, “hidden” available
              updateInterval: 100,
              onStart: null, // disable onStart feature with null
              allowDevices: [“Galaxy S10”], //If you want to limit devices to display info, use this.
              // allowDevices: [“RASPOTIFY”, “My iPhoneX”, “My Home speaker”],
              I have the Spotify logo but that’s it.
              An idea ?
                @ELMAGO
                any of your spotify player needs to be turned on. did u install raspotify?
                • E Offline
                  ELMAGO @Guest
                  @Sean
                  a player was running, the Galaxy S10 precisely.
                  I just want to make a display of the music that passes on some players.
                  Why need Raspotify?
                    @ELMAGO
                    if u has no need to play spotify on rpi, raspotify is not required.
                    anyway, to get current spotify playback info, one of your spotify player(galaxy s10) should be activated already before MMM-Spotify. The module doesn’t know which player is available until the player is activated.
                    • E Offline
                      ELMAGO @Guest
                      @Sean said in MMM - Spotify:
                      ok, I understand and I do not want to play spotify on this Rasp, I just want a display of music that passes on some players. So why when I do not restrict devices and change device, the module detects it well, whereas when I restrict it there is no display.
                      • E Offline
                        ELMAGO
                        Someone will have an idea?
