    MMM - Spotify
    22 Posts 3 Posters 7.8k Views 3 Watching
    • E
      ELMAGO
      Hello
      I would like that if the name of the device is for example, DESKTOP-GLTBMFB as on the image, the module does not appear.
      alt text
      S ? 2 Replies Last reply
        sdetweil @ELMAGO
        @ELMAGO Ok… let me feed that back…
        you have multiple devices capable of playing spotify music, and you would like to prevent/limit the active playing display to just certain devices (your phone, but not your teenagers for example).
        • E
          ELMAGO
          @sdetweil said in MMM - Spotify:
          Indeed, I have several devices. I use my computer at work, for example, and I do not want it to work on my MagicMirror at home.
            sdetweil @ELMAGO
            @ELMAGO got it… I don’t know how to solve the problem, but didn’t understand your need at the beginning.
            • E
              ELMAGO
              ok thanks
                A Former User @ELMAGO
                @ELMAGO
                Isn’t this working?
                E 1 Reply Last reply
                • E
                  ELMAGO
                  I did not use this module in fact, I install it and I come back to you.
                  Thank you
                  • E
                    ELMAGO @Guest
                    @Sean
                    I just finished the installation.
                    If I do not put anything in this option, I see what Diffuse Spotify, but if I use this option :
                    module: “MMM-Spotify”,
                    position: “top_center”,
                    style: “default”, // “default” or “mini” available
                    control: “hidden”, //“default”, “hidden” available
                    updateInterval: 100,
                    onStart: null, // disable onStart feature with null
                    allowDevices: [“Galaxy S10”], //If you want to limit devices to display info, use this.
                    // allowDevices: [“RASPOTIFY”, “My iPhoneX”, “My Home speaker”],
                    I have the Spotify logo but that’s it.
                    An idea ?
                    ? 1 Reply Last reply
                      @ELMAGO
                      any of your spotify player needs to be turned on. did u install raspotify?
                      • E
                        ELMAGO @Guest
                        @Sean
                        a player was running, the Galaxy S10 precisely.
                        I just want to make a display of the music that passes on some players.
                        Why need Raspotify?
                          @ELMAGO
                          if u has no need to play spotify on rpi, raspotify is not required.
                          anyway, to get current spotify playback info, one of your spotify player(galaxy s10) should be activated already before MMM-Spotify. The module doesn’t know which player is available until the player is activated.
                          • E
                            ELMAGO @Guest
                            @Sean said in MMM - Spotify:
                            ok, I understand and I do not want to play spotify on this Rasp, I just want a display of music that passes on some players. So why when I do not restrict devices and change device, the module detects it well, whereas when I restrict it there is no display.
                            • E
                              ELMAGO
                              Someone will have an idea?
                                @ELMAGO
                                I’ve updated, Update module and try again.
                                      module: "MMM-Spotify",
                                      position: "bottom_right",
                                        allowDevices:["My iPhoneXI Pro"], // < - Change this to your device name.
                                • E
                                  ELMAGO @Guest
                                  @Sean
                                  Hello
                                  and thank you, how to update the module?
                                    @ELMAGO
                                    git pull in MMM-Spotify directory.
                                    • E
                                      ELMAGO
                                      • E
                                        ELMAGO @Guest
                                        @Sean
                                        Hello
                                        it’s perfect, great. For several devices I have to put a comma and [“XXXX”]?
                                        The Spotify logo, does not disappear?
                                        ? E 2 Replies Last reply
                                          @ELMAGO
                                          Yes. ["My iPhoneXI Pro", "DESKTOP-ABCD", "RASPOTIFY"].
                                          You can hide it by CSS or change the logo image file to what you want.
                                          • E
                                            ELMAGO @ELMAGO
                                            @Sean
                                            So, I went around the problem by making transparent the image that you apply.
                                            Thanks for your help.
                                            It works nickel …
                                            Really, thank you
