    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 83.9k Views 19 Watching
      Mr.Gysy
      Thanks for help. fixed that 2 parts. Now no error for config but site still cant be reached :/
        Mr.Gysy
        no idea anymore or tips? :(
        Reply Quote -1
          sdetweil @Mr.Gysy
          @Mr-Gysy sorry, unclear on error you are seeing
            Mr.Gysy
            changed something, now webpage shows: my connection has been rejected?
              sdetweil @Mr.Gysy
              @Mr-Gysy so, steps to debug
              from another system can u access the mirror itself
              http://ip:port
              if no, then either firewall, or mirror config prevents.
              address: or whitelist or both
              if address is localhost, then ONLY apps on the SAME PHYSICAL system can access
              if address is 0.0.0.0, then apps can access from any network connection
              if address is something else, some specific ip, then apps can only access server thru the hardware adapter that provdes that address. think if u had two network cards, and wanted to restrict access to only one of those cards…
              now, once you’ve got that
              we go to whitelist
              now you can constrain access to specific systems on that netwokr, or groups of systems by address range (or applied mask)
              so, to start I’d do address: “0.0.0.0” and whitelist :[],
              means any system from any network
              can u access the mirror app
              now can u access the remotecontrol app insde the mirror?
                Mr.Gysy
                adress is set on 0.0.0.0
                and whitelist []
                on pi itself same from browser : 192.168.178.40 rejected the connection
                  @Mr-Gysy said in [MMM-Remote-Control] Can not access remote control module:
                  192.168.178.40
                  need the port too
                  http://192.168.178.40:8080 (thats the default port)
                    Mr.Gysy
                    alt text
                      sdetweil @Mr.Gysy
                      @Mr-Gysy remove after the port. Let’s make sure default works
                        Mr.Gysy
                        alt text
                        same :/
                          sdetweil @Mr.Gysy
                          @Mr-Gysy ok. Check the address of the pi
                          sudo ifconfig
                            Mr.Gysy
                            sudo ipconfig
                            sudo: ipconfig: Command not found
                            thats not good :/
                              Mr.Gysy
                              ifconfig worked
                              alt text
                              M 1 Reply Last reply
                                sdetweil @Mr.Gysy
                                @Mr-Gysy not ip, if
                                sudo ifconfig
                                  Mr.Gysy
                                  dont work
                                  alt text
                                    sdetweil @Mr.Gysy
                                    @Mr-Gysy please read and copy/paste
                                    sudo ifconfig
                                    U are typing iPconfig
                                    Not p
                                      Mr.Gysy
                                      thats the screen above :)
                                        sdetweil @Mr.Gysy
                                        @Mr-Gysy no screen above shows 2 times the command
                                        ipconfig
                                        I need you to use
                                        ifconfig
                                        Windows system uses ipconfig
                                        Linux does not
                                          Mr.Gysy @Mr.Gysy
                                          ifconfig worked
                                          alt text
                                          that is “ifconfig”
                                            sdetweil @Mr.Gysy
                                            @Mr-Gysy ok. U have two interfaces.
                                            What is address: in config.js?
                                            • 3 / 4
