    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 85.0k Views 19 Watching
      motdog
      Thanks for all the feedback. I get the concerns and why its set up that way. No big deal at all
      • A
        AshDarko
        So I still get access denied, but if i change
        ipWhitelist to [] then my phone can now access the remote page.
        Just dont understand when I have address the correct ip for my phone it says access denied to that same ip in the terminal
        Changed:
        ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:10.100.10.1",],
        To:
        ipWhitelist: []
          Mr.Gysy
          I know the topic is old, but may someone can help me.
          The module is shown on my screen but when I want to enter via Browser it always shows: This site cant be reached.
          alt text
          when erase the // from the config: The screen shows me an error, I should install a config data.
          Can someone help me?
          S O 2 Replies Last reply
            sdetweil @Mr.Gysy
            @Mr-Gysy position: “bottom_right” needs a comma after when the next line is NOT a comment
            • O
              OldSunGuy @Mr.Gysy
              @Mr-Gysy
              I see you have:
                  adresss: “0.0.0.0”,
              It should be:
                   address: “0.0.0.0”,
              Just a user helping another user
                Mr.Gysy
                Thanks for help. fixed that 2 parts. Now no error for config but site still cant be reached :/
                  Mr.Gysy
                  no idea anymore or tips? :(
                  Reply Quote -1
                    sdetweil @Mr.Gysy
                    @Mr-Gysy sorry, unclear on error you are seeing
                      Mr.Gysy
                      changed something, now webpage shows: my connection has been rejected?
                        sdetweil @Mr.Gysy
                        @Mr-Gysy so, steps to debug
                        from another system can u access the mirror itself
                        http://ip:port
                        if no, then either firewall, or mirror config prevents.
                        address: or whitelist or both
                        if address is localhost, then ONLY apps on the SAME PHYSICAL system can access
                        if address is 0.0.0.0, then apps can access from any network connection
                        if address is something else, some specific ip, then apps can only access server thru the hardware adapter that provdes that address. think if u had two network cards, and wanted to restrict access to only one of those cards…
                        now, once you’ve got that
                        we go to whitelist
                        now you can constrain access to specific systems on that netwokr, or groups of systems by address range (or applied mask)
                        so, to start I’d do address: “0.0.0.0” and whitelist :[],
                        means any system from any network
                        can u access the mirror app
                        now can u access the remotecontrol app insde the mirror?
                          Mr.Gysy
                          adress is set on 0.0.0.0
                          and whitelist []
                          on pi itself same from browser : 192.168.178.40 rejected the connection
                            @Mr-Gysy said in [MMM-Remote-Control] Can not access remote control module:
                            192.168.178.40
                            need the port too
                            http://192.168.178.40:8080 (thats the default port)
                              Mr.Gysy
                              alt text
                                sdetweil @Mr.Gysy
                                @Mr-Gysy remove after the port. Let’s make sure default works
                                  Mr.Gysy
                                  alt text
                                  same :/
                                    sdetweil @Mr.Gysy
                                    @Mr-Gysy ok. Check the address of the pi
                                    sudo ifconfig
                                      Mr.Gysy
                                      sudo ipconfig
                                      sudo: ipconfig: Command not found
                                      thats not good :/
                                        Mr.Gysy
                                        ifconfig worked
                                        alt text
                                        M 1 Reply Last reply
                                          sdetweil @Mr.Gysy
                                          @Mr-Gysy not ip, if
                                          sudo ifconfig
                                            Mr.Gysy
                                            dont work
                                            alt text
                                            • 3 / 4
