    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 81.6k Views 19 Watching
      Mykle1 Project Sponsor Module Developer @motdog
      @motdog
      You can clearly see that it is working remotely.
      It would not allow connection with address: "localhost",. Take your working config and carefully add my entry for Remote-Control, address and ipWhitelist It should work.
        motdog @Mykle1
        @Mykle1 Awesome! Thanks so much for your help.
          @motdog
          So, does that mean that it’s working for you now? If so, mark the topic as solved.
            AshDarko
            Hi, i too have the same issue. I have changed my router IP to be something other than 192.XXX.X.XX
            Could this be the problem? I can access via browser on the Pi…?
            When i run the remote in browser on the pi, i notice in terminal this message:
            MMM-Remote-Control customMenu Requested, but file:/home/pi/MagicMirror/config/custom_menu.json was not found
            i receive an “Access Denied to IP address 10.100.10.1” in terminal and a message on m y phone saying the device is not allowed to access your mirror
            Here is config code:
            address: "0.0.0.0", // Address to listen on, can be:
            	port: 8080,
            	ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:10.100.10.0/24",], // Set [] to allow all IP addresses
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            And here is my module code:
            		module: 'MMM-Remote-Control',
            		/**position: 'bottom_left',**/
            			customCommand: {},  // Optional, See "Using Custom Commands" below
            			customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
            			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
            			/**apiKey: "",         // Optional, See API/README.md for details**/
            The module code is pretty much the defaults.
              AshDarko
              I have just commented out the custom menu for now, so ignore that terminal message about it
              			/**customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below**/
                motdog @Mykle1
                @Mykle1 my only other question is when I was at a friend’s house I tried to pull up the remote to show them the mirror & nothing happened on their wifi or cellular. I’m guessing on the white list I would have to input my phone ip address?
                S R 2 Replies Last reply Reply Quote 0
                  sdetweil @motdog
                  @motdog lot more than that…
                  by default your home router blocks ALL incoming requests (or should anyhow) so you would have to open a port and map incoming requests on that port to your mirror machine (and port) by using the routers admin function… some providers do not allow this
                  (this is called port forwarding)
                  second, the IP address of the router on the internet is assigned dynamically, and might change…
                  some of us use a dns mapper to define a specific NAME to our router as it appears on the internet
                  ( I use dyndns.org to map a known name to my router ip address, today my routers internet ip address is near 47.220.177.xxx)
                  third, the ip address of your phone will be randomly assigned too… their router, maybe over phone link connection… so , here u might have to say 0.0.0.0 anyone…
                    retroflex Project Sponsor Module Developer @motdog
                    @motdog If you open up a port for outside access of MM you’ll have to whitelist all IP’s since your phone changes IP. You will then expose it for everyone. This includes the config.js file, which might contain passwords to calendars etc. So be careful! Best option is to connect to your network using VPN. It is possible to setup a VPN server in some routers.
                      sdetweil @retroflex
                      @retroflex he will still have to whitelist everything, or use Listen: 0.0.0.0
                        motdog
                        Thanks for all the feedback. I get the concerns and why its set up that way. No big deal at all
                          AshDarko
                          So I still get access denied, but if i change
                          ipWhitelist to [] then my phone can now access the remote page.
                          Just dont understand when I have address the correct ip for my phone it says access denied to that same ip in the terminal
                          Changed:
                          ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:10.100.10.1",],
                          To:
                          ipWhitelist: []
                            Mr.Gysy
                            I know the topic is old, but may someone can help me.
                            The module is shown on my screen but when I want to enter via Browser it always shows: This site cant be reached.
                            alt text
                            when erase the // from the config: The screen shows me an error, I should install a config data.
                            Can someone help me?
                            S O 2 Replies Last reply Reply Quote 0
                              sdetweil @Mr.Gysy
                              @Mr-Gysy position: “bottom_right” needs a comma after when the next line is NOT a comment
                              • O Offline
                                OldSunGuy @Mr.Gysy
                                @Mr-Gysy
                                I see you have:
                                    adresss: “0.0.0.0”,
                                It should be:
                                     address: “0.0.0.0”,
                                Just a user helping another user
                                  Mr.Gysy
                                  Thanks for help. fixed that 2 parts. Now no error for config but site still cant be reached :/
                                    Mr.Gysy
                                    no idea anymore or tips? :(
                                    S 1 Reply Last reply Reply Quote -1
                                      sdetweil @Mr.Gysy
                                      @Mr-Gysy sorry, unclear on error you are seeing
                                        Mr.Gysy
                                        changed something, now webpage shows: my connection has been rejected?
                                          sdetweil @Mr.Gysy
                                          @Mr-Gysy so, steps to debug
                                          from another system can u access the mirror itself
                                          http://ip:port
                                          if no, then either firewall, or mirror config prevents.
                                          address: or whitelist or both
                                          if address is localhost, then ONLY apps on the SAME PHYSICAL system can access
                                          if address is 0.0.0.0, then apps can access from any network connection
                                          if address is something else, some specific ip, then apps can only access server thru the hardware adapter that provdes that address. think if u had two network cards, and wanted to restrict access to only one of those cards…
                                          now, once you’ve got that
                                          we go to whitelist
                                          now you can constrain access to specific systems on that netwokr, or groups of systems by address range (or applied mask)
                                          so, to start I’d do address: “0.0.0.0” and whitelist :[],
                                          means any system from any network
                                          can u access the mirror app
                                          now can u access the remotecontrol app insde the mirror?
                                            Mr.Gysy
                                            adress is set on 0.0.0.0
                                            and whitelist []
                                            on pi itself same from browser : 192.168.178.40 rejected the connection
                                            • 3 / 4
