    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 83.8k Views 19 Watching
      sdetweil @Mr.Gysy
      @Mr-Gysy remove after the port. Let’s make sure default works
        Mr.Gysy
        alt text
        same :/
          sdetweil @Mr.Gysy
          @Mr-Gysy ok. Check the address of the pi
          sudo ifconfig
            Mr.Gysy
            sudo ipconfig
            sudo: ipconfig: Command not found
            thats not good :/
              Mr.Gysy
              ifconfig worked
              alt text
                sdetweil @Mr.Gysy
                @Mr-Gysy not ip, if
                sudo ifconfig
                  Mr.Gysy
                  dont work
                  alt text
                    sdetweil @Mr.Gysy
                    @Mr-Gysy please read and copy/paste
                    sudo ifconfig
                    U are typing iPconfig
                    Not p
                      Mr.Gysy
                      thats the screen above :)
                        sdetweil @Mr.Gysy
                        @Mr-Gysy no screen above shows 2 times the command
                        ipconfig
                        I need you to use
                        ifconfig
                        Windows system uses ipconfig
                        Linux does not
                          Mr.Gysy @Mr.Gysy
                          @Mr-Gysy said in [MMM-Remote-Control] Can not access remote control module:
                          ifconfig worked
                          alt text
                          that is “ifconfig”
                            sdetweil @Mr.Gysy
                            @Mr-Gysy ok. U have two interfaces.
                            What is address: in config.js?
                              Mr.Gysy
                              you mean this? 0.0.0.0 or?
                              alt text
                              • O
                                OldSunGuy @Mr.Gysy
                                @Mr-Gysy
                                config.js has a typo
                                adresss: “0.0.0.0”,
                                should be.
                                address: “0.0.0.0”,
                                  Mr.Gysy
                                  @OldSunGuy said in [MMM-Remote-Control] Can not access remote control module:
                                  address: “0.0.0.0”,
                                  what a shit failure.
                                  THANKS VERY MUCH!!!
                                    sdetweil @Mr.Gysy
                                    @Mr-Gysy hm … the default according to the API used is 0.0.0.0 if not specified.
                                    The typo would make it not specified…
                                    • O
                                      OldSunGuy
                                      Isn’t the default localhost?
                                      General property option
                                      On my rpi I get the ::1 IPv6 address
                                      pi@raspberrypi ~ % getent hosts localhost
                                      ::1             localhost ip6-localhost ip6-loopback
                                      pi@raspberrypi ~ %
                                      Both IPv4 and IPv6 addresses are in my local /etc/hosts file:
                                      pi@raspberrypi ~ % grep localhost /etc/hosts
                                      127.0.0.1       localhost
                                      pi@raspberrypi ~ %
                                      • W
                                        Welle05 @Mykle1
                                        @Mykle1 said in [MMM-Remote-Control] Can not access remote control module:
                                        Thank you so much, also from my side! I spent hours to look for the mistake and it was again the wrong written “address”
                                        • 4 / 4
